Here is something to do with an unused half of an LM358 - if you don't already have a Lo-Battery indicator. I am wanting to use rechargable batteries, where the voltage differential between a "good" battery and one that needs charging, is maybe only two tenths of a volt. I need a distinct "break point", a mushy audio tone won't do.
Hysteresis is not featured here, but I don't think it should be an annoyance. I originally started designing with a LM393 type comparator (or section "A", 1/2 LM392), but my simulation shows the LM358 to actually be better behaved - so far as not spiking during turn-on/off. Of course my simulation is not as good as a breadboard or prototype.
C2 and R4 values can be varied to give a fairly wide range of PPS/PW times. Not counting amplifier or comparator current, this circuit (with RC as shown) draws less than 100uA. I suggest staying with R values from 470 to 2k, and C between 10nF and 680nF. Short duration pulses may not be visible even at higher flash rates.
The original design (from Dave Johnson and Associates) uses 680 ohms and 680nF, and blinks slowly (about 1/2 Hz) with relatively long pulse duration. You shouldn't have much trouble finding an RC combination yielding a visible, low current alarm. Of course, different LEDs and R5 will affect results. Sorry I can't tell you precisely which LED to use, but LEDs are cheap, right?
Although you can't tell from the picture, the LED on time is about 260us.
