Originally posted by ivconic
However, normally slower filter causes delay, depending on which part of waveform you detect, so if 1265 is actually quick recovery like TGSL, you would expect equal depth with big deep objects.
Could it be coil differences?
I have not yet experimented with size of "integrator" capacitor following the synchronous detector JFETs - sort of a hidden part of the filter. Could make a difference.
I'll say that my Tesoro Compadre often detects big objects (soda can and larger) very deep. I can lift the coil way above the ground - but not a meter, maybe 2/3 meter. I get excited at first, such a nice signal, then raise coil way up -- still beeps, forget it, buried kitchen sink or something!
But strange, sometimes very big coin not register as well as smaller coin or about same - probably because 5.75" coil.Well -- keep testing!
Cheers,
-SB
Right?
