Does any on Know what resistor can be changed to adjust SAT speed on the Classics? I also want to mention that C 31 controlls the Tone, and it can be adjusted to go higher or lower by changing from 10N to a different value.
SAT speed on White's Classic 3?
Sat Mod
Jeff,
Heres what a whites tech told me!
"You can either increase the resistance of r32 or increase the capacitor value of c16"
Can someone explain How to increase the resistance of R32 or the Value of C16,
And what resistor should I use and where.....
Email me if you would...
Sat Mod
Götz von Berlichingen
let me see if I understand exactly what you are saying!
With further research I found the resister Value as 220 k ohm on R32...
Resister color code on R 32 was as follows. Red=2 Red=2 Yellow=four 0000 and Gold
band for tolerance. So if I want to increase the "Resistance" in R32 I would add another
220K ohm resister in "Series" with the one Thats already on the Circuit Board, correct?
Or should I use a larger resister other than the extra 220K ohm? How about a quick
diagram to show how to use a switch to toggle back and forth from normal SAT to Slow Sat
Doug
Doug, there is Mr. Bill Crabtree. he does all mods on all detectors on low price.
http://www.surfscanner.com/
Contact Mr. Bill at Surfscanner Detectors at (508 )457-4805
Yours
IDX Pro Mods
Kt315
I already asked Mr. Bill! Besides, it will take up to six weeks for it to get done according to what someone else said..... I want to learn to do something for myself anyway!
I thought the purpose of this forum was to learn and help others to learn also! Well so far
I have learned about resistor color codes, how to use an ohm meter, series and parallel wiring of a resistor or capacitor. I have a Mint teknetics Mark-1 LTD that I will most likely
need to work on one of these days as East Texas is so busy and People have had there detectors there for over 2-years ...Also! I'm doing Mods to my detector that Mr. Bill doesn't do and he told me already that he doesn't want to
work on a detector that has already been worked on by someone else because he doesnt
want someone saying that his work was insufficient and that was after spending $1,300.00 on detectors from him in the past. Another reason to learn and do
something for "Myself" I would like to learn also to be confident enough in myself to
do the Tone Mod on my mint condition XL Pro, That Mr. Bill doesn't do!! I figured the IDX is a Good place to start...
"Note" All My mods up to this point have been "Physical Alteration" with just basic knowledge needed to alter the looks an placement of control housing. Like on my LTD shown below that I should have never sold!!!!!!!
Doug
try change U5 on FET type for first. TL062, TL072, TL082, LF353, LF442, TLC072, LT1057CN8, TLC272, TLC277, TLC27M7, TS27M2, TLE2062, TLC2262, LT1057CN8.
The 2262 is just a dual CMOS opamp. I don't think noise, offset, or bandwidth are critical in this application. So use any dual CMOS opamp... You could probably use a TL072/082 JFET opamp... they are very easy to find.
- Carl
my english is internationally clear reading. not problem there! niga of USA says on spanglish. why you understand the niga and do not understand me writing clear classic English?Originally posted by duggr View PostPardon me if I don't fully understand your English!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It might be easier to remove R32 and connect in an external potentiometer (for example, 1MEG) with some flying leads. Then you can adjust the pot until you get the SAT speed you require. Then, using your multimeter, measure the pot resistance. Do this for both the fast and slow settings you require. After that determine the closest fixed resistor values, and switch these in or out of circuit using an external switch.Originally posted by duggr View PostWith further research I found the resister Value as 220 k ohm on R32...
