On a VLF detector such as a classic 3, Now What happens when you build a Dc to Dc converter to boost battery voltage from 12v to 24v and use that Voltage across the tx oscillator only. if you knew that the transistors could handle the power? The currEnt would be cut in half, but what would it do in general if I tried this on an analog vlf detector? I own a fire extinguisher. Thank you for your response-------------
Doug.
Doug.
