A component going up in flames so to speak, is a sure sign of overvoltage, or excessive current. There could be some other component which is depleted below it's optimal operating range, but not completely shorted which allows the detector to work for few hours, but gradually, same components fail time and time again. After replacement of those components, you may want to monitor the quiescent current when the detector is powered on. Based on that you might be able to see whether the detector is power hungry above and beyond it's normal operating range. That could give indication of some other unknown component failure.
The coil and cable need to be suspect as well.
