Some of you might have spotted a great way to "up" the depth of the standard Tesoro Silver Sabre Plus. If not here it is!
Take the BOTTOM of the 1K resistor from the sensitivity control and replace it with an 8K2 with the other end connected, not to ground as before, but to the cathode of the diode nearby on the circuit board (-5V0). VOILA, now, wwhen you turn up the "sensitivity" to maximum, you will gain upto 2 inches IN GROUND over the standard Silver Sabre Plus.
Also, you can cut the PCB track which supplies the +5V to the transmit oscillator, and run the oscillator directly off the batteries. This gives an extra 1" too, so now your "old" SS+ is as good as a modern Tesoro machine, but for zip increase in price.
ENJOY!
