delta pulse
  • delta pulse
    i found away to make deltapulse give sound noise like pulse star
    this make the device more sensitve
    it is simple add opamp non inverting voltage summer before the audio stage
    i will post the result soon
    there was a modification from Koljaj... you maybe have seen it...
      what i think
      hi KT315
      thanks you
      iam thinking of this
      it should give more sensetivity and the rest button still work
      what is your opinion
        what iam thinking is that will let you adjust the voltage V2 to get some clik sound
        and this give more depth
        iam working in this part now
        what do you think KT315?
          results
          after doing modifications
          results
          1 euro = 43 cm air test
          coca can =90 cm
          still trying the best value of resistors in voltage summer parts
