Minelab Colt question
  • Minelab Colt question
    Could someone please tell me what the value is for the 104 trimmers in the Minelab MusketeerColt, one of these trimmers are for the all metal mode threshold and the other 104 trimmer is for the discrimination mode threshold. I want to tweak the threshold to where my Colt "buzz's" when the sensitivity is max'd out. The top of the trimmer in my Colt is broke off (someone must have tried adjusting it before I got it). If any of you know the value of the 104 trimmers please let know at my email address [email protected] Thanks! Steve.
    If it's marked "104" that means 100k.
      Thanks Carl. Is there anywhere a person can find a chart,etc, that list numbers and values. Thanks again. Steve.
        you don't really need a chart , can be done in your head.
        same / similar to the resistor colour code but easier.
        as carl says , 104 is 100k
        103 is 10k , 102 is 1k ,etc etc,
        the last digit is the same as the colours , brown is 1 ,red is 2 ,orange is 3,and yellow is 4
        once you have got your head around the resistor colour code , then trim pots ar a doddle.
          just had another thought , not sure if its free advertising though , i have no conection to it at all.
          download electrodroid onto an android phone , brilliant app , lots of good features on it , and free , including resistor colour codes , common available values and numerical values such as what you require.
          i use it often , 555 calculator , op amp calculator , 317 calculator , the list goes on , it's crammed with usefull stuff.
          yup , sounds like i'm advertising the app doesn't it ??
          lucky to find it on market place.
            Clarification through examples...
            104 --> 10 x 10^4 = 10 x 10,000 = 100,000 = 100k
            333 --> 33 x 10^3 = 33 x 1,000 = 33,000 = 33k
            472 --> 47 x 10^2 = 47 x 100 = 4700 = 4.7k
            681 --> 68 x 10^1 = 68 x 10 = 680
            150 --> 15 x 10^0 = 15 x 1 = 15
              Even easier - the last number tells you how many zeroes there are after the first 2 numbers.
              e.g.
              104 --> 10 plus 4 zeroes --> 100,000 = 100k
              333 --> 33 plus 3 zeroes --> 33,000 = 33k
              472 --> 47 plus 2 zeroes --> 4,700 = 4k7
              681 --> 68 plus 1 zero --> 680 = 680R
              150 --> 15 plus 0 zeroes -> 15 - 15R
              This is exactly the same as Carl's example, but easier to work out.
              Simples.
                Thanks a bunch folks, as they say never too old to learn something new.
