PI Project
  • PI Project
    OK, finally... here is the schematic, PCB, and parts placement for the PI design. Yes, I know, the PI schematic does not make much sense, what with all the jumpers. I will post simplified versions with extraneous parts removed, ASAP. Please note the resolution of the PCB... if you print it on a 300dpi printer you will need to scale the image by 50% first.
    Schematic - 300 dpi GIF (174K)
    PCB - 600 dpi GIF (258K)
    Parts placement - 300 dpi GIF (178K)
    Re: PI Project
    I'am interest of timing description of circuit for TECH
    ______________________Value________________Descrip .
    1.-Mosfet_On---------------T1=50us-100us?_______Power_Coil
    2.-Mosfet off----------------T2/T3=aprox?_________Reverse Power
    3. Pause?--------------------T3 aprox?____________ Nothing
    4. Invert integrator-----------T4/T5?_______________ very interest! Compensated Ground
    4.Integration-----------------T5=
    .__________________________________________ Comparator/Sound
    10. Mosfet On-------------- T10
    11. Mosfet off---------------T12
    12. Pause?------------------T13
    13. NonInvert integrator-----T14__________________¡Its correct?
    14.Integrati{on------------- T15
    Sorry for my poor Inglish! !!!!
    Thank You / Gracias
      Re: PI Project( Thanks Carl)
      Very Good Carl Thanks,
      Unfortunately my best scope has developed a focus problem, and I can't find the service manual. I have it, just can't lay my hands on it. I really am anxious to look over your latest revision, but I think some serious houskeeping is going to be the order of the day till I find the missing manual.
      Thanks Again
      Russ
        Re: PI Project
        What is the actual size of the pcb?
          3.5 x 4.0 inches n/t
            Re: PI Project
            Not quite sure what all you're looking for. I am working on an explanatory article, I'll try to get a preliminary version posted ASAP. It will cover some of the timing ranges.
              Re: PI Project
              Hi Carl,
              It thanks for publication diagram of the metal detector. I ask, of graphs in measure points (TP), is possible me about or message as well as in building of coil - diameter of wire - diameter of coils, arrangements of jumpers.
              Did you try coils about dimensions 1 x 2 metre?
              I'm sorry my English.
              Help my. Thank you very much, Good luck.
              Gustaw
                Bandwidth
                Carl
                I don't know what all the compensation on the amplifier does, but the main feedback seems to have a 15 usec TC. That is longer than I expected. Is this typical of PI's? I thought they had wider bandwidth than that. This may change my opinion about sampling and noise.
                I thought they were about 100 kHz.
                Robert
                  Re: Bandwidth
                  The main feedback cap was thrown in for experimentation. I am not currently using it, and most designs I've seen do not, either. The rest of the compensation mess is to accomodate different opamps.
                    Re: PI Project
                    OK, yes, I plan to make waveform plots of the test points, as soon as I have time to write up some instructions.
                    The coils I wound are 28 AWG, which is smaller than I wanted... I'd recommend 24 AWG. I wound 150mm (40 turns), 200mm (30 turns), and 250mm (24 turns). So far, just testing with the 200mm. I have not tried any meter-sized coils.
                      Re: PI Project
                      Thanks very much for answer.
                      Probe "coil" 1 x 1 m AWG 20 ... 24 (8 turns).
                      I ask plan to make waveform plots.
                      Thank you very much.
                      Good luck
                      Gustaw
                        Re: PI Project
                        Hello Carl!
                        Please, tell me about Q4, IC9 (7 pin).
                        I don't understand about jumpers or tumblers ?
                        Have you a photo (image) of detector or pcb with IC.
                        Sorry for my bad English.
                        With best regards Viktor
