Now build proscan
  • Now build proscan
    yo he construido varios detectores de metales pi pero solo detectan a unos 55 cm objetos grandes. Ahora quiero construir el PROSCAN solo que quisiera saber que alcance tiene para ver si vale la pena.
    A los que lo han costruido, me podrian decir hasta que profundidad ha detectado?
    Gracias. Saludos
    I have constructed several metal detectors pi but single they detect to about 55 cm great objects. Now I want to construct the single PROSCAN that it wanted to know that it reaches must to see if it is worth the trouble.
    who has build? to say me until depth has detected
    Thanks Best regards.
    Re: Now build proscan
    Hi Serafin
    Check out pulsdetektor a German PI site.
    Easy PI projects with good results.
    Chris
    Pulsdetektor
      Mi amigo Carlos de Argentina construyó el Proscan y siempre le ha dado muy buenos resultados. Él me dice que una lata de cerveza alcanza 30-35 cm y el 709 lo reemplaza por el LM 318 basado en el circuito de Mark Stuart.
        Say What?
          My friend Carlos from Argentine saw me that the Proscan detects a beer pot at 30-35 cm. He replace the 709 Proscan's section by the LM 318 section of Mark Stuart's detector.
            The PROSCAN that build detects an aluminum tin of 330 cm to 50 cm. of distance in the air and a coin of 2 cm. of diameter detects me to 32 cm. with a coil of 20 cm. of diameter
            carlos
