Nice schematic. I think power consumption is less than 100 mA so you can use smaller size (transistor looking) voltage regulator like 78L05.
Also CD4024 can drive some low load itself so you can use small buzzer with capacitor or LED with resistor to make cheaper simpler version of that pinpointer without second transistor.
Can pinpointer detecting thin chain?
NUPI thank you, excellent documented!
I drew the PCB of the pinpointer compact design with non-SMD parts.
Plate size is 40x40mm. If you like the design you can use it in your kit for sale.
The upper 3 pads is for coil, middle 2 pads is for supply, lower 2 pads is for motor.
I wonder if you could do some testing with the usual materials, to compare data:
Aluminum foil of chocolate: 3x3mm, 2x2mm and 1x1mm
Copper wire 0.4mm diameter: 3mm, 2mm and 1mm
I do not have a gold chain ...
Important - Important
I made two mistakes in the schematics.
One in the schematic (schematic NUPI 3) misses D2
In thisschematic is restored.
In schematic (pinpointer NUPI 2014.jpg) I made a major mistake. There, the wires 1 and 2a
on the coil is swapped.
In the schematic pinpointer NUPI 2014 (2)is restored.
Sory for the caused inconvenience .
L1 = 330uH L2=1.6mHOriginally posted by Nupi View PostThe new Schematic[ATTACH]28952[/ATTACH]
Inductance values are very close to TX and RX of some VLF coils.
Can somebody to connect VLF coil to this schematic?
It may show some interesting results!
Great Bente,Originally posted by bernte_one View Postok here is what i have done last 2 hours
plan was to make single sided board
th components could be soldered on top, or on bottom by changing orientation (trimmers, trasistors ...)
layout is made with top and bottom tracks
sorry i am noob
[ATTACH]28996[/ATTACH]
[ATTACH]28997[/ATTACH]
[ATTACH]28998[/ATTACH]
I see two small mistakes.
I think you need BD139 and D1 turn 180 degrees.
Is it possible that you make one with a normal components, no smd?
For clarity, I have not made with SMD.
So, I do not know how the circuit will do with SMD components.
It looks nice.Originally posted by Qiaozhi View PostFor stripboard layouts I use DIYLC -> http://code.google.com/p/diy-layout-creator/
This software is platform independent, which means I can run it under Linux in native mode.
Highly recommended.
I go first practice a time with it. Thanks.
Highly recommended.
I agreeOriginally posted by Waikiki_Sweep View PostOnce I have made a 300uH coil for SurfPI by winding wires on plastic pipe 3 cm. diameter.
Than I was just shocked why detecting range has shrinked from 25 cm. to 3 cm. for the coin with all same parameters.
Since I have learned how shape of magnetic field strongly depends on shape of coil.
If you really want it go deep so make coil as flat as you can and as bigger diameter as situation permits.
So I am voting for "disk" shape of core and a "ferrite ring" as a variation of disk shape. (You can have an air inside of a disk keeping similar parameters of magnetic field on some distance.)
Probably ferrite cap can behave as a disk too if windings are made outside cap but not inside cap.
Variants of "transformer" shape of coils like "T", "U", "cap" will reduce range drastically because all magnetic field will be concentrated in small area instead of spreading far away to the targets.
Who do not believe in my theory welcomed to check it in practice.
But with ferrite ring? I do not know.
nice board picture- seems something like fritzing software?
will do one layout in tht and one in smt
Hi Bente,Originally posted by bernte_one View Posti am on the way to make a sprint layout file from nupis shematic
if you all can wait a little bid i will continue
or if someone is faster please give a short info here
That would be great if you would do that.
Yesterday I made a drawing of the pointer.
I is, like I made it.
With this layout, he does well.
Maybe you can use it
