Hi All,
I just purchased one and intend applying a few mods, but need to wait until it arrives.
I was wondering what is the standard Xtal for these?
I see some say 1.9MHz some 2MHz others 4MHz.
Minelab have two versions of the F1A4, one with a small coil, high frequency and timings designed for Minimal Metal mines and an UXO version supplied with large coil, lower frequency and timings to suit deep unexploded ordinance.
I guess this would explain why some have the 4MHz Xtal and others the 1.9MHz (not sure about the 2MHz, maybe for close proximity to ones running 1.9MHz)
Woody I wonder if the firmware is the same for each type the MMD and UXO and they select appropriate timings with PROM strappings?
Independent Mine detector comparisons and testing showed that the UXO version had the deepest reliable detection ranges in hot ground of all the detectors then available.
This is an air test, but in an in ground test the A1F4s were the only ones besides the Vallons that didn't loose appreciable depth. This is an aluminium target one that is a good gold analog.
(Source Systematic Test & Evaluation of Metal Detectors (STEMD) Interim Report Laboratory Tests Italy EUR 22536 EN 2006)
Swapping the coils between the MMD and UXO may not have produced the same results since Minelab confirm that the MMD and UXO versions have different timings.
Cheers
Kev.
Cheers
Kev.
