Sandbanks
  • thanks for watching and searching the mistake on my pcb version
    hope we can do that in german forum unteil end of november
    pcb?s arrived yesterday
    maybe some other interested diy builder from europe? i could send it with a letter?
    i didnt fount ten people, so some pcbs are over
    • @BerntOne,,,,,Let us know how your build goes,,,I'm half way through building my 100mm x 0mm DIY Polones pcb,,I should be finished by tomorrow,,,I'll let you know if it works or not. Regards,,,Marty
      • Well,,,,I really don't know what to say,,,,,This is the 8th version of the PI Polones unit I've made over the last 2 years and to me it's the same old story, I just haven't been able to get any one of them working yet. I used to think it was all my fault and put it all down to lack of experience or lack of skill or something but now I don't think it's me - it's the Polones. One of the pcb's I made was a proper pcb and I spent a whole week taking my time with it,,,when I fired it up the Mosfet instantly got hot with or without a coil,,,same thing with all the other 7 versions,,,this version I've just made blew the 79L05 as soon as I switched on,,I swapped it out and this time the mosfet got seriously hot so I turned it off for fear of damaging any other IC's etc,,,,I don't think I'll be making another Polones. It takes me the same length of time to make other, better PI's like the Mirage, that are proven and work 1st time so I know it's not my soldering etc,,,Really disappointed with the Polones as I was hoping to get at least 'one' working to add to my collection. I'm going to spend my time a bit more constructively now and concentrate on my 3rd IDX PRO as I've finally built a few working Omega coils that I've got to work for the IDX/IGSL and TGSL,,,,I found that can build these coils better and more accurate than my DD's and concentrics,,I've had no luck whatsoever with concentrics,, I'm a bit better with DD's but struggling to make coil shells for them till my new Hotbox is finished,,,Omega's are really easy to tune and I'll be forming some coil shells for them once my new hotbox is built. I'll post a new thread on the Omegas when I've finished them and tested them etc,,Regards,,,Marty
        • i know that feeling
          waste of time and money, but still not given up
          • @BerntOne,,,,I wish you more success than I,,Good luck with your build. Regards,,Marty
            • Omega's are really easy to tune and I'll be forming some coil shells for them once my new hotbox is built. I'll post a new thread on the Omegas when I've finished them and tested them etc,,Regards,,,Marty
              Interested in this subject
              • detector runs smooth with irf630
                but i will try some updates like irf840, another damping resistor and maybe another gain factor
                sometime the irf630 gets immediatly hot when i use other coils with higher resistance than 1R and more ?H
                22AWG (0,6mm) copperwire 300?H is ok, but i think i will get trouble when building a 1m frame coil with 0,8 wire 8 turns + 2m of connection cable
                maybe you have any suggestions
                • Arionas. Voc? pode publicar ou arquivo .lay aqui para poder fazer um PCB caseiro. Gostei muito do seu design. OBRIGADO.
                  • Originally posted by gerson View Post
                    Look all post ....and downlod pcb and sxema....
                      • Arionas. Yes, I already have all the downloads, so I liked yourslayout by having the potentiometers attached to the printed circuit board. I need the B / W file to print a starter card. Thank you
                        Last edited by gerson; 07-08-2020, 02:01 AM. Reason: sorry for problems with google translator
                        • just a short feedback after months
                          pi polones (sandbanks clone) works soild
                          usefull to use one additionel offboard pot instead of the trimmer, so it is easy to change coils without opening the detector
                          works good with 3s 18650 liion cells,
                          use small speakers instead of piezo
                          some improovements can be made by adding some other resistor and caps here and there
                            Did you try an IRF840?
                            • irf840 is ok you can use it
                              • An IRF740 also works very well.
                                If the transistor is replaced by a mosfet,
                                the voltage divider must be adapted to the required gate voltage of the mosfet
