  • pigeon
    Originally posted by etwert View Post
    Dear pigeon, I did not doubt your correctness. The problem just exists.
    Sincerely, etwert
    I believe 7805 is reverse
  • etwert
    Sincerely, etwert
  • mehmet_dag
    Originally posted by amindevil View Post
    I have the unlimited version of hex I can share it with you guys
    Hi Dear Amin , is it original or hacked version ? Can you email to [email protected] to check. Thx for your kind interest.
  • pigeon
    hi lay file joker forum version
    hello
  • etwert
    Dear pigeon, in this pcb 7805 does not receive power supply
    voltage. Sincerely, etwert
  • YIVANKA
    https://simplemetaldetector.com/puls...imination-fix/
    OK, I'll try it later. Thank you 6666 very much .
  • 6666
    Originally posted by YIVANKA View Post
    [ATTACH]53886[/ATTACH][ATTACH]53887[/ATTACH][ATTACH]53888[/ATTACH]
    Delay:Coil Error!
    How to resolve it & how to cancel the hex limit of times?
    RE, the coil error here is a link that may over come your problem
    as it says" this problem is often encountered when the components used do not match the detailed description given by the developer of FelezJoo. Since the source code is not available, it is necessary to find a hardware solution."
    After a few months of research for the problems of discrimination and "Coil Error" in the Felezjoo PI, I finally find a temporary solution that can make.
  • YIVANKA
    Send it to my email or..
  • sbalio1
    Hi pigeon and amindevil can you chare your hex file please help.
  • sbalio1
    Hi pigeon can you post lay6 if you have it
  • amindevil
  • kt315
    Delay:Coil Error!
    I grasp you have to buy programmed u-controller from kooyhar paying some dollars.
    i do not see its free.
  • pigeon
    pcb mustafa felezjoo pi
  • etwert
    I don't have a pcb from mustafa. I have lay6 from sabios, post # 1076.
  • YIVANKA
ID:	358695Click image for larger version
ID:	358696Click image for larger version
    Delay:Coil Error!
