Originally posted by Phiphi
It's a bit tricky to do, but if you can put a 0.1ohm resistor in the ground side of the coil, this will display the coil current waveform without the high voltage transients. What you should see is as the image on my post no.53. Under the cover that you have removed, the braid termination can be unsoldered by using a slim iron and lifting the wire out of the slotted terminal with slim taper nose pliars. I presume that lead free solder has been used as per regulations, but I found it easier to melt by applying a bit of tin/lead solder first. I also made a heat shroud out of thin brass to prevent any risk of damage to the thread into which the plastic cap screws.
Eric.
