Vallon VMH3CS Mine Detector
  • Chet
    I will consult my favourite reference work 'The Electronics Empiricist'.
    The picture shows a detector coil in use for radio reception. [ATTACH]36415[/ATTACH]
    Eric.
    Hi Eric
    I presume you are referencing the vast empirical knowledge and experience in electronics that you have acquired over the many years.
    I found the websites below on the R1132 receiver. It has quite an interesting history. It looks like there were a number of manufactures.
    Have a good day,
    Chet
    Receiver Type 87 R1132A Mil Re MILITARY U.K. different makers for same model, build 1941, 9 pictures, 4 schematics, Great Britain , tubes, semiconductors
  • rickb
    "I will consult my favourite reference work 'The Electronics Empiricist'."
    Is this a book? Google says it doesn't exist. I found references to a magazine called The Lightning Empiricist published by Philbrick.
    Rick
  • ivconic
    [QUOTE=Ferric Toes;218365]
    Collins or what?
    /QUOTE]
    No, they belong to me.
    The l.f. receiver to which the search coil is connected is out of the picture and under the nearest receiver and power supply. To take the picture from the other side and it would have been dominated by the face of a Morbiere grandfather clock close to the coil. The picture was to illustrate that the vertical plane was good for the reception of radio signals and not good for a metal detector. Also an alternative use for a Vallon shaft which has been doing this job long before I managed to get a couple of control units to play with. BTW. some search coils by other manufacturers make better radio antennas than my coil, due to the use of graphite paint shielding which has less attenuation unless you spray on several coats.
    A free ferrite rod if you can identify the receivers and the manufacturer. Clue - they are not American.
    Eric.
    Tough!
    On first glance i can't recognize it and be sure.
    But i like your methods and ideas!
  • Ferric Toes
    [QUOTE=ivconic;218363]
    Collins or what?
    /QUOTE]
    Eric.
  • STAVROSNU
    Dear Eric,
    I have just sent you a private message with the requested informations.
  • ivconic
    ...The picture shows a detector coil in use for radio reception. [ATTACH]36415[/ATTACH]
    Eric.
    Collins or what?
    btw http://www.radista.info/en_hf_radio.html
  • Ferric Toes
    Hi Eric
    Thank you for the nickel test, lobe information and photos. I really like your probe and its great performance.
    Have a good day,
    Chet
    I realised yesterday evening that I have been disregarding my own advice. That is, to have the detector coil horizontal to minimise noise pickup (coil axis vertical).
    I have been testing the probes laying horizontal, when they should be vertical. For broadcast radio use, a ferrite antenna is horizontally mounted to get maximum signal from the magnetic component of the carrier wave. Also radio direction finding frame antennas are vertically mounted on a swivel base. That is not what you want for a ground searching metal detector as minimum r.f pickup is the desired situation both for open coil and ferrite probe.
    Sometimes probes are used in a horizontal situation so I am going to put together a differential arrangement which is noise cancelling in all directions. Will that work on the Vallon I wonder? I will consult my favourite reference work 'The Electronics Empiricist'.
    The picture shows a detector coil in use for radio reception. Click image for larger version
    Eric.
  • Chet
    I have now applied the helical outer shield of lead tape. This is 0.1mm thick and adhesive backed, so it is easy to apply. I ceased using this some years ago but still have some left, so I might as well use it up in these experiments. The first picture shows the set-up for measuring the range to a nickel off the side of the coil and the orientation of the coin. There are three lobes of detection for a coin in this orientation; one each, top and bottom and the other all around the side, with a sharp minimum as you move from one lobe to the other. With a sphere you get a fairly uniform sensitivity all around the core, with no dips.
    Second picture shows connection from lead tape to core ground wire.
    [ATTACH]36409[/ATTACH]
    [ATTACH]36408[/ATTACH]
    Hi Eric
    Have a good day,
    Chet
  • ivconic
    Some problems I have come across with certain ferrite rods that cannot be determined by reading specifications are -
    1. Some rods ring mechanically and cannot be damped out.
    2. Some rods are microphonic such that if you hit a rock they give a false signal.
    3. Some rods respond to the earth's field even when the detector has earth's field cancellation. This is not just swinging the rod but the baseline zero changes if the rod is positioned NS and then changed to EW; acting a bit like a fluxgate sensor.
    4. Rods from the same batch respond slightly different.
    Right now I have two seemingly identical rods bought at the same time, wound and shielded the same and tested on the Vallon. One is noisier than the other.
    Eric.
    Yes i know exactly what do you mean.
    In the past i tried to examine closer some core materials.
    Right now i am thinking on the same method, but considering the size and volume of the rods; a bit larger coil diameter will be needed to perform this simple experiment:
    Point is to establish some sort of "reference", a referent feature for classifying rods.
  • Brian Deese
    Hi Brian,
    I am not sure if the VMC1 is electronically the same as the VMH3CS. Maybe it is and it is programmed differently, or in fact there is no difference. I have been informed that the VMH3CS is programmed differently for different customers and markets, so there are a few unknowns.
    Electrical and electronic noise can make a difference to the achievable ranges. My workshop is noisy and I have have a communications receiver that reaches as low as 75kHz. I cannot use it at all on a wire antenna up to about 2MHZ for all the noise, so I use a directional frame antenna that I can rotate and find a null for noise or a max for wanted signal. The frame antenna is actually a shielded PI metal detector coil! In spite of the shield I can still get good signals from short wave stations up to 10mHZ, then it falls off rapidly. Cell phone transmissions you would not think to cause interference as they can be 100 times higher in frequency, but the high field strength from the repeaters and the non-linearity of the detector RX results in demodulation to interference frequencies. The best situation is to get away from power lines, cell phone antennas, computers, fluorescent lights, etc, etc. One useful hint is that the vertical orientation of the search coil is the worst for picking up interference; always have it horizontal.
    Eric.
    Horizontal,and on a board to elevate it right off the ground. I think I read somewhere that was your recommended test procedure. I'll take it out of the city and have at it again. Pretty fancy for a mine detector though.I have tried a couple other mine detectors and they are awful.I like the Vallon I would like one like yours,the collapsible vmc1 is heavy on your arm.I think you did right putting it on a belt.
  • Ferric Toes
    Originally posted by Brian Deese View Post
    Hello Eric its good to see you play, I have been away from Geotech for a while also.I just signed on and found your post. I have a Vallon VMC1 that I have been very impressed with,I havent used it in the field yet though. If there is anything I can do for you regarding that model I am at your disposal.I made a video of air testing a us nickel this morning. I'm in the city,and I just set it on the parking lot,so its not the greatest test im sure. Youtube killed the video you could read the numbers on the ruler before upload. But the results were 10" very strong signal,11" good repeatable digable signal,just loses it at 12" the sensitivity set just to the first notch of 10 any more and it falsed from interference. https://youtu.be/BJb7XAZut7Q
    Hi Brian,
    Eric.
  • Brian Deese
  • Ferric Toes
    4in x 3/4in probe core test. 2
  • Ferric Toes
    Hi Eric
    Thank you for the information in the previous post. Your latest coil (10” on a nickel) wow! That is something to be proud of. What does the field around the side of the coil look like with this kind of probe? Does it still pick up the nickel at several inches?
    Have a good day,
    Chet
    The external field is exactly that of a bar magnet. Going out sideways from the middle of the winding, I get 7.5 - 8in on the nickel; the coin being in the same plane as when measured off the end of the rod.
    Eric.
  • Ferric Toes
    Eric,
    From looking at the photo of your probe and doing some fast back of the envelope calculations I guess that you are using AWG 30 Teflon insulated wire that is .024 inches OD?
    thanks
    Joseph J. Rogowski
    Hi Joe,
    The overall diameter of the wire measures 0.022in with the internal tinned copper core being 0.009in (0.25mm). I presume it is Teflon insulation as it is quite difficult to strip. I have a 10,000ft reel of the stuff, bought some years ago on ebay, so it is good to start using it.
    Eric.
