Originally posted by Ferric Toes
Thanks for testing the 1x1 aluminum foil. Wondering why you couldn't detect the 1x1inch but could detect the 1.5x1.5 inch aluminum foil. I charted their time constant plus a couple others. A 156kHz resonance, 1.5uH coil requires a 735 ohm damping resistor to critical damp. Decay time constant=.0015/735(2usec). Could the reason be, the 1x1 foil TC(1.7usec) is shorter than the coil decay TC(2usec) where the 1.5x1.5 foil TC(2.4usec) is longer than the coil decay TC(2usec)?
