2nd Chance PI
  • phred01
    I have traced back to the original web site in Russia and found this interesting post
    Translated by google
    I need more feedback from field!
    v1.2.8
    - Restore digital filter algorithms originally used by Fandy
    - Optimization of digital filters
    - Failure of the OK button to reset the filter. Now the reset should only be done during start-up and change the guard time in the menu
    Due to the continuous construction of the dynamic "background image processor" with a weak signal from the object coil, the signal strength will be seen on the LCD.
    Output of the second coil on the sensitivity recovery side. The same overall functionality and sensitivity reaches the detector only after the start. If the threshold is set high barriers
    This detector operation may resemble some type of dynamic detector operation. With strong signals, the effect is unlikely to be significant even for small signals, if it has
    information activities, this is not a problem. The dynamic nature of the construction work "background image" generates a small signal is masked
    use of the "barrier". Touching the coil to ground can generate a signal for a short time, but after a while the processor changes the "background image"
    Start the detector and change the protection period we do when the coil is in the air, and not on the ground.
    It is suggested to put "Volume raise" on 1/8
    to come back to the beginning
    pawol
    Post subject: Re: Chance
    Posted: Fri: Jul 08, 2016 23:21
    firmware Chance PI v1.30
    Slowly this is beautiful
    List of changes:
    v1.2.9
    - code optimization
    - Limiting the maximum height from the frequency of the generated sound. Sometimes the frequency was too great and could no longer hear it. Now the range of frequencies generated
    This is 100Hz and 200Hz for a distortion object of 5.5kHz
    - Changed the masking algorithm.
    Currently, there are 4 masking modes:
    1 - colors only
    2 - only iron
    3 - only gold and bronze
    4 - only silver, copper and aluminum
    v1.3.0
    - Small optimization digital filter
    - Added submenu "VDI1 - left limit" and "VDI2 - right limit." Set there and the boundary criteria VDI1 VDI2 is used in masking mode. Mumer VDI is the number of LCD segments
    VDI on the indicator in the top line is numbered from left to right. The area on the left side of the LCD to "VDI1 is the left limit" area for gold and bronze and the "VDI2 - right limit" area to the right of the LCD is an area for copper, aluminum, silver.
    The area between "VDI1 is the left limit" and "VDI2 is the right limit" is the area for the iron.
  • phred01
    found answer in the tread will have remove & change components
  • phred01
    Just checked original cct compared to the 2nd chance some differences Flyback clamp, coil damping resistor & R11 from + bat to socket X3 pin 14. My main concern is the fly back clamp what impact does this change have.
  • phred01
    Thanx Glowian now I can upgrade the unit built a yr ago. Then will wind the coil for it
  • glowian
    Good morning
  • phred01
    Originally posted by dantech View Post
    tried to download but site is difficult navigate in particular that payment is needed in zolties is there paypal available? secondly can the whole suite be download @ once rather than piece meal and asking payment each time?
  • dantech
    v026 is released
  • DonCaffeDelaSkobalj
    Hi Don,
    You have made some good suggestions.
    The original Chance PI design used an OP37 amp that is much more capable than the NE5534. If you have not already done so, take a look at the original Chance PI schematic.
    Dan
    Thank you Mr.Baum7154
    Dantech new Chance PI project look good and worth trying. If Mr.Dantech find time and want to improve Chance project i may give him new information how to hit GOLD and Silver coins with 100 kWatts and much more impulse power. Same techinque as is used in GPR-s ground penetrating radars and particle accelerators.
    It is matter of work many very sharp nano impulses several kV amplitude with slopes even in picosecond domain. So instead using one or hundred microsecond impulses with low amplitude 400-500V, with big pulse width and slow fronts we are using for deep penetrating targets many nano impulses from several tenths to several thousands, packed in only one micro second impulse.
    Similar technique used in Mineab PI detectors known as MPS - multi impulses in one period transmitting and sensing. And physicist Bruce Candy and Minelab know how to make good detectors.
    DonCaffeDeLaSkobalj
  • baum7154
    Hi Don,
    Dan
    Dobry dzień dantech.
    Great project. Any new info.
Name:	2nd ChancePI_schematic (1).gif
    If you can try to improve dynamic range of 2'nd Chance PI OP using some good and fast R2R rail-to-rail OP instead old NE5534.
    Good examples are OP from microchip. My choice are MCP 660-669. Very high gain x bandwidth range of 60MHz, with very fast Skew rate 32V per microsecond are ideal for amplifying nano and microvolt signals from fast decaying targets like pure gold nuggets, golden rings, golden seeds, small golden coins at high deep, or normal size golden coins in highly mineralized ground.
    Also clamping diodes at should be schottky type smd diode. At output of OP directly to op-out pin should be some pure resistive load from 10 to 600 ohm to stabilize OP circuit in wide range of input impendances. S-parameters tuning. Good values from 330 to 620 ohm.
    Transmitting part should be corrected. Instead old PFET 9640 with 11A drain-source current, 200V breakdown voltage and, 0.5 Ohm,drain-sourc4e channel we need something newer with continuous drain current over 50A, with peak impulse current over 200A and drain-source resistance in 0,0xx range,
    For penetrating deep ground soil we need hyper sharp fronts of PI impulse. It means rising and faling times in several to tenths of nano-seconds. To get this we need high speed high current driver special designed for draiving high current mosfets/igbt transistors with big input gate-source capacitance Cgs from several nano farads. To very fast charge this parasitic capacitance we need very high current pulse direct from mosfet driver.
    My choice is
    ixd630 30A peak pulse current
    http://www.ixysic.com/home/pdfs.nsf/www/IXD_630.pdf/$file/IXD_630.pdf
    Puting 3 in parallel we have 90A current pulse. Square this value multiple with coil inductance and devide by 2 and multiple with number of target kicks per second and you will know how much energy hit the gold target. This imply using very high electrolytic capacitor usualy connected to source of mosfet to supply driver and mosfet with enough peak current in range 100A-200A. Value bigger than 50 000 uF will be fine. This capacitor is main source of detector power and only he could release several tenths or biger enregy pulses in properly designed coil.
    And for the end negative voltage pump LT1054 must be synched with ATMEGA328 directly to avoid wide range of interference problem due to uncorrelated currents in all parts of PI metal detector.
    These are my little suggestions for you and other builders. Try it and see it. I don't ask nobody to belive me - but to understand me.
    Reg,
    DonCaffe
  • glowian
    Hi, got coil error 0us pulsing sound where to start fix problem??? coil 320uH 1.2ohm??
  • dantech
    That feature works properly. I have verified one.
    Remember that every calibration/recalibration (eg. auto coil delay test during the start or filters reset) should
    be done when the coil is raised up and away from metal objects.
  • ripsdevala
    Need to check, when turn on backlight from menu, the zero button working normal, backlight off=cannot zero
  • dantech
    Unfortunatelly I have not free time. In my opinion documents I gave are enough to build 2nd ChancePI without problems.
  • ripsdevala
    Btw, i really like to build ur pcb version, but as you know it was fail or i miss something.
    If you have time plis redraw the sprint layout, so it can be clear what to omit and not.
    With my original updated chance pcb i think is not compitable with ur firmware, when i set up something like barrier or go to setup menu its alwasy ringing, and i should restart the md to make it normal again.
Name:	view cek-800x588.JPG
