Polish Pi
  • Originally posted by Andi68 View Post
    Yes, I thought the 16 meters might be too much
    16cm x 3.14 x 32 = ? not 16 meters?
    • Read carefully, I did not write that my coil has a wire length of 16m
      • read carefully 16cm coil has 16cm x pi x 32 = 16 meters length.
        For the test I made a coil, 16cm in diameter, 0.4mm enamelled wire, 32 turns, 1.6 ohms and 343 ?H. ARE YOUR WORDS NOT MINE.
        • What do you want to tell me? My words, your words, doesn't matter.
          What matters is that I wrote, 16 meters are too long.
          12.56 meters are quite good
          • @Andi68
            How many uH does your coil measure? I am going to do a Polish PI soon myself. Thanks
            • make a coil 250-300microH less than 2R
              use at least 0,6mm solid core wire
              for example 18turns, diameter 35cm, wire 0,8mm
              • 16cm, 25 turns, 0,4mm, 1,3 Ohm, 203?H
                • @ bernte_one and @ Andi68
                  Thanks to you both for the information.
                  • I found in the HFE4011 a relationship between the power supply and the output transition times. In one of mi polish pi i had to add a 11 vols regulator to the 4011 and then works much better.Click image for larger version
                    • Originally posted by Rodelio View Post
                      I found in the HFE4011 a relationship between the power supply and the output transition times. In one of mi polish pi i had to add a 11 vols regulator to the 4011 and then works much better.[ATTACH]50933[/ATTACH]
                      Well known formula in electronics
                      V = 5,95 x 10^5 x √U (м/с),
                      V = speed of charged particle, in CMOS case speed of electrons;
                      U = accelerating voltage or velocity of electrons in V;
                      • Hello there
                        I have a simple question:
                        Does it really help to use 16V battery pack instead of original 12V for POLONES ?
                        because I've heard some people say that 16v supply is better and some say 12v
                        my polones has a 4 cell 18650 which is a 16v pack and i don't have a power supply so I tried myself by draining the battery down to about 13v
                        but I didn't notice any difference really
                        So what's the deal in this topic? 12v better?
                        • Originally posted by Mr.Jaick View Post
                          Hello there
                          Amigo sempre utilizei 3 c?lulas 18650 o tempo de uso ? extremamente alto totalmente carregado chega a 12.6v nominal de 11.1v funciona perfeitamente.
                          • Originally posted by Emersonpaz View Post
                              Hello there
                              answer them. better is 48V onboard voltage battery of a boat, 1000us PULSE WIDTH and Gold Of Atocha you are seeking.
                              • Comment
