Polish Pi
  • Bayu
    Originally posted by Mr.Jaick View Post
    my experience on two sample delay resistors:
    i tried 20k for both (27uS sample delay) with a 50cm spiral flat coil about 350uH
    detects gold very good but as soon as you try to go over some clean ground it does not work, too sensitive to capacitive effect of ground
    have to shield it
    but increase the resistors up to 27k both, it works like a champ
    40uS delay if i remember correctly and very little ground effect
    still catches gold
    12gram bracelet 18k : 80cm
    2gram ring 14k(not sure) : 17cm
    I am seting freq 750hz 33k pin 1 from4011 use 10k
    33k use trimp 50k to setting
    330 from 6 lf357 replace 10r
    Detec ring 1,8grams 18k 17cm in red ground
  • Bayu
    @Bayu, what did you use as your schema for the VCO? Please show us.
  • Andi68
    The detector gets faster when you get theApplying Sanbanks Mods
  • Mr.Jaick
    That's funny.
    When you say "detects gold", most people immediately assume you mean gold nuggets. Rings (whether made of gold or not) enhance the flow the eddy currents, and are the easiest targets to detect.
    That is indeed
    "nuggets" oh boy...
    detecting rings with this detector is a big achievement on it's own
  • Qiaozhi
    those are the detection depths
    we're not giants
    That's funny.
  • Mr.Jaick
    That's a huge bracelet and ring!
    I assume you actually meant 80mm and 17mm?
    we're not giants
  • dbanner
    i think his coil is not 350-380uH but less. with 560 Ohm he has to get near-to-good picture.
    I concur. The coil itself is under the so called " inhabitable zone".
    You may want to wind a new coil, and don't be surprised to see different results.
  • Qiaozhi
  • Mr.Jaick
    have to shield it
    still catches gold
  • surfdetector
    Originally posted by Bayu View Post
    [ATTACH]54603[/ATTACH]
    [ATTACH]54603[/ATTACH] Green [ATTACH]54603[/ATTACH] Pin 10 4011
    Yellow pin 5
