GOLDSCAN 5 SCHEMATIC QUESTION
  • eclipse
    On my GS4 build which im working on in parallel with this I used same integrator as this one and it all worked. Timings are as follows:
    Sample1 going to Channel 1 (main) +
    Sample2 going to Channel 2 (gb) +
    Sample3 going to Channel 1 (main) -
    Sample4 going to Channel 2 (gb) -
    This same scheme im using for GS5.
    Looking at the photos I think some components are not shown in the drawings, I guess its not that complete.
    Im thinking just to get the things going you can connect the output of the op amp going through 10k to the summing op amp stage to GND, thus not using the entire GB channel so you dont need to stuff those parts right away. This way you can check with less components whats going on with the main channel, hopefully get it going.
  • Jose
    Yes. I think sequence is wrong. I compared to GS4 schematic. I made correction to GS5 schematic, I think it should look be like this:
    I hope I'm not wrong, but in your scheme it should be:
    A ... corresponds to B.
    B ... corresponds to A
    D ... corresponds to C.
    C ... corresponds to D.
    In GS4, the first pulse corresponding to the delay enters through the non-inverting input, (+).
    In the GS5, the mentioned pulse must enter through the inverting input (-).
    Is that the integrator of the GS4, is different from the GS5.
    Please check, and have someone tell me if I'm wrong.
    Jose
  • dbanner
  • Jose
    For adjusting the setting to "0" volts, the gates of the J113 should be connected to GND, the same as the GS4.
    Leg 3 adjusts to a few millivolts negative, just when the AOP changes at the exit, leg No. 1 and walks in the values mentioned, around 4 negative volts, (1/4 LT1114)
    The integrated figure TL052, in some photo I saw it as TLC2262.
    The sequence of pulses, from the time base, with the integrators seems to be wrong. Compare with the GS4 scheme.
    Jose
  • eclipse
    Yes ive connected it to -5V. On the op amp output there voltage should be around -4.3V, im getting -3.8V
  • dbanner
    Somewhere earlier in this thread someone mentioned this correction. This point should read -5volts?
  • eclipse
    Actually the schematic works, kind of.
    I have voltage drifft issue right now (after detection signal voltage driffts to +5v) but I guess this is normal - I haven't installed 2x470K + 5M6 resistors.
    Adjusting all 50K trimmers is a bit hard. For 2nd attempt to build this section I didnt stuffed those. Also GB section is not stuffed.
    Audio is a bit iffy. Probably output voltage is not optimal for this audio and may need adjusting.
    This section is not working correct in my build, you can try on yours but I couldn't get it work fine. (I've changed values of R22 - 10K, R2 - 10K)
  • kt315
    Originally posted by Alexismex View Post
    Well mens,
    I give to the forum the GS4 schematic and the Baracuda pulse detector that i myself reengineering ...it is the only way to have the circuit good design.... if i will have the GS5 in my hand i will make the same work
    You did an excellent job Alexis. but i ask you to give more pics of a board in high resolution. try to distribute
    the work between active GT members.
  • WM6
    Agree. We should not measure someone work by personal intolerance.
  • dbanner
    Ivconic contributed NOTHING to this forum? Really? No wonder he left. Many others have made countless and valuable contributions to forum. That is not disputed. I only mentioned ivconic because he no longer is here and some of us greatly appreciated his efforts and help. GMT King cobra is excellent piece of reverse engineering so kudos to you. For me using altium to design small single side dip PCB is like using 3D printer to make paperclip. Sprint layout might seem primitive but to make paperclip all you need is piece of wire.
  • Alexismex
    Well mens,
  • pustareka
    no contributions. NOTHING. he took old famous schematic drawn William Lahr and castrated it up.
    while King cobra is:
    1. long waiting and monitoring of ebay for the GMT in broken state, i waited years!
    2. i paid for overseas shipping from USA. thats VERY EXPENSIVE!
    3. the board was fully resoldered, every component was measured.
    4. i learned P-CAD 2006 for to do a board copy. ivconic used only primitive sprint layout!
    5. i opened a coil and learned it inside.
    i gave all info, schematic, BOM file, pcb. FREE.
    i did not take Lahr's schematic for the project, i did all myself
    PS. i wait somebody from you sending me GS5 pcbs and i will give you absolutely detailed PROJECT.
    agre total kt315 truth .castrated shemas. big thanks goodwork goodman William Lahr.
    make new schemas need big brain. MD need smart head no gum and pencil.
    big brain plus big experiment goal is ok.
    thank you kt315, man hanor.
  • Qiaozhi
    You did an excellent job on the King Cobra.
    I think most members of the forum know those who contribute and those who don't. Obviously some people may not have sufficient electronics knowhow to feel confident, and are understandably nervous to "show and tell" when it comes to their own projects. There are also others who just leech ideas from the forum, and have no intention of ever posting anything useful. Unfortunately that's just the nature of forums in general.
    Yes, it can be very frustrating when you see the same newbie questions again and again, but I've noticed over the years that most people are willing to help within the limitations of their knowledge. You just have to take the rough with the smooth. Personally, I've learned a lot from the Geotech forums.
  • kt315
  • dbanner
    I would like to extend a special thanks to Ivconic for valuable contributions made to this forum over the years, especially his work on developing the golden sabre light project. I for one will miss his presence here. There have been many others too, so thank you all.
