I have been trying alternative mosfets as some newer devices appear to have a better spec than the IRF740 which I have used for many years. The latest device tried is SiHA22N60E which at first glance appeared to be very suitable. i.e. Vds 600V, Rds 0.23 ohms and Coss (output capacitance) of 90pF. By comparison the IRF740 has Vds of 400V , Rds of 0.55 ohms, and Coss of 330pF at 25V Vds and Vgs 0V.
Another transistor that works well is the P5NB40 which also has a Vds of 400V and a much lower Coss of 72pF at a Vds of 25V. The Rds is a bit higher at 1.5 ohms though. This device is good for short sample delay times as the lower capacitance in parallel with the coil/cable results in a higher ringing frequency and a higher value resistor for damping. However, for both devices the Coss is voltage dependant and rises for lower values of Vds. In the case of the IRF740 the figure rises to around 600pF and the P5NB40 to 110pF at 10V Vds. 10 to 15V Vds is that which is likely to be encountered on a PI metal detector.
In the case of the SiHA22N60E the value of 90pF is for Vds of 100V and which reduces to 73pF at 480V. Below 100V the Coss rises rapidly such that at 10V it is about 3000pF: an unacceptable figure for a PI transmitter. Ringing, with a 300uh coil and 1.5m of RG58 coax (100pF/m), is severe due to this high value of added capacitance. Damping of 150 ohms is required rather than the 1K for the P5N40. Substituting a P5N40 mosfet gives a smooth recovery as seen at a two stage x1000 gain preamp o/p.
P5NB40 with 1K damping.
IRF740 with 1K damping.
22N60E with 1K damping.
22N60E with 150 ohms damping.
Looking at the Coss capacitance graphs, it does appear that running the mosfet at a higher Vds can be beneficial in minimising this unwanted capacitance. For the IRF740, 20V appears to be the value below which the Coss starts to rise fast. For the P5NB40, 15V would be a good voltage as the Coss is still below 100pF, but rises fast below 10V. These voltages may give rise to excessive current in low resistance coils unless low repetition rates are used. The next task is to raise the coil resistance and/or insert series resistance such that the mosfet can run at the higher voltage but maintain a reasonable pulse current and repetition rate.
Eric.
Eric.
