Which PI Machine To Build?
  • Which PI Machine To Build?
    Thinking of building a PI machine from one of the designs here, i'm looking for something that works well and can be used for a bit of serious detecting. Which machine and coil should i build, if the machine will work well i don't mind going for something more complex.
    Vikki(uk)
    How much experience do you have building and testing electronic circuits?
    Can you solder well and have a multimeter and O'scope?
    A good start is buying a kit from Silverdog in the UK.
    Find information, resources and relevant links for diydetector.co.uk. This domain may be for sale.
    He currently has three kits. Search the geotech forum and read about them.
      Yes i can lay my hands on test equipment, is the minipulse a good choice from silverdog or one of the other offerings?
      Many thanks.
      Vikki
        i am actually building up the lucaslab pi / pi polones
        seems realistic simple, very often build in middle in latin america
          Many thanks.
          Vikki
          All information on the MPP REV-E is here -> MPP Beach REV-E
            Does the mpp beach version have its own pcb or do you modify the silverdog pcb?
              MPP Beach is just a different name for the REV-E version. There are no modifications required.
                I'm new at this so bear with me.
                Out of the 3 kits Silverdog sells, which one goes the deepest?
                Can any of these kits be made to work with coils sold on the market today or do you have to build your own?
                Thanks!
                  do all 3. then after your first experience in electronics you will never ask us which one goes deepest.
                  pleasure
                  Anatloy
                    Thanks!
                    Minipulse Plus is the deepest if tuned correctly. Baracuda is the second deepest. Surf-PI is the smallest and simplest design, but still with good depth.
                    All three can use commercial coils.
                    Both Minipulse and Baracuda have comprehensive build documents, but the Surf-PI does not.
                    Minipulse Plus
                    Geotech Baracuda
                      do MPP+ because it is well documented.
                      pleasure
                        I used to be an electronic technician...but that was 25 years ago. lol
                          Minipulse Plus
                          Geotech Baracuda
                          Thanks!
