I didn't need another project -
perhaps Charles Garrett had in mind 'Gallo Effect'. yes, perhaps the gallo of coin is a bit much more deeply in salt water.
I have an original production schematic from Garrett, so can check those posted against mine; in due course. Production proper started in 1983; earlier ones were largely for test purposes. I'm not sure when it finished, but would likely coincide with the release of the SeaHunter 2.
I haven't examined the circuit board yet in the one I have, but in some of the posted schematics above, there are some differences in components, plus, maybe some errors e.g. never heard of a 704. I haven't found a serial number yet, but maybe there is one inside which would give a clue as to it's age.
Charles Garrett made an interesting observation in one of his letters. "I have found personally that United States coins can be found in salt saturated sands much more deeply than the same coins through air. Perhaps the salt water makes the target surface more conductive".
Eric.
thank you Qi. i did not have this marketing blurb. good COVID-19 project.
yes, this detector have full diggest of pics and schematic. i bought this Garrett, first i did i rewinded
a transformer in charger on our standart, 220V AC. then i did notice Ni-Cad cells are dead all.
Is this the schematic for Garrett XL500 Sea Hunter.?
I've also attached some marketing blurb.
"... in 1982..."
38 years old and yet in such good shape, that's rare.
I assume there is no mcu inside, only analog parts?
-but spotted this on ebay at the end of August.. Price was $250 which I thought was reasonable for the unit which appeared in good condition, but was untested. Shaft, charger, and belt are all there too. It arrived today and I was pleasantly surprised that the unit was even better than anticipated. It doesn't appear to have had much use at all. I charged the battery and with coil connected it did not work i.e. no TX pulses. However that is not a problem as I was involved in the development of this detector in 1982 and the electronics is very straightforward. In fact, I plan to upgrade it with all the latest circuitry and a Li-ion battery instead of the heavy Ni-cad cells. I will use a different search coil as in those days coils were unshielded. Should help to while away the coming autumn evenings and the Covid restrictions. It was interesting that this detector came from Florida and was the result of a find in a storage container sale.
Eric.Tags: None
