Originally posted by qedqad
coil 180cm for golden mask deep hunter 3 se pro
Thank you all. I have a question to complete this topic. I want to reverse engineer the device, but I am facing a problem, which is the presence of a strong black substance attached to the electronic parts on the board itself. How can I remove this substance without losing the device or damaging it? I will attach pictures of the article.
from your first story you must set the resistor in parallel to one turn, while on the sketch i see you show resistor in serial.
delete it anyway. connect turns directly.
I apologize for the error in the previous post, in this picture you will find the correct and sure information for the two files 125 cm and 180 cm, knowing that the final file is stable and has excellent depthAttached Files
