Originally posted by steaua581
View Post
Delta Pulse
Delta Pulse
Originally posted by raff33 View Postfor me i have CD4066 bcn without probleme
I am using cd4066...
The detector works better end stable ...with that cd4066 ...
The only problem i have and still can"t find from where the problem comes when comes to detection distance....at one moment the detector started to work incredible i used to get a coin at 30 cm...but not far later the detection sensitivity decreased again and now again im geting a coin at 17-20 cm... with the 1x1 coil 16 turns im getting a large gasoline canister at 1,60M in the air wich is poor....i wonder from where the problem comes...
Marius
The only problem i have and still can"t find from where the problem comes when comes to detection distance....at one moment the detector started to work incredible i used to get a coin at 30 cm...but not far later the detection sensitivity decreased again and now again im geting a coin at 17-20 cm... with the 1x1 coil 16 turns im getting a large gasoline canister at 1,60 in the air wich is poor....i wonder from where the problem comes...
Marius
what you do?
c1=15nf or 22nf * c7=220uf or 1000uf * R1=680k or 470k * R5=2k2 1w or 680R 1w * R6=680R or 1k * R47,49=2k or 1k * PR1=200k or 220k..........?
and i think if you have some ciramic composants........(your probleme)
sorry for my bad english
Regards.....raff33
postoje razlike izmedju seme i pcb-a:
D9 , D10 (4066) pin14 ide na +12v po pcb-u a na semi ne
D9 , D10 (4066) pin 7 ide na -E po PCB-u a na semi ne
D2 ,D3 (453pin 16 ide na +12v po PCB-u a na semi ne
D2 , D3 (453pin8 ide na -E po PCB-u a na semi ne
R47 , R49 -1k ili 2k
R! 470k ili 680k
PR1 250k ili 220k
C1 22 nf ili 15 nf
C7 1000mf ili 220mf
C32 4700 mf ili 10000 mf
sta je ispravno?
Delta Pulse
Originally posted by raff33 View Posthi Marius,
what you do?
Regards.....raff33
I am building again this detector from scratch...i will use components as you sayed . and i will post results...
Can i substitute BC546 with BC547?
Marius
Marius
REGARDS............Raff33 GOOD LUCK
Originally posted by raff33 View Posthi abdellatif ;
happy to meet you in the forum ........................., kt315 and ather poeple............................................ ..........will help you........
.........good luck
REGARDS........raff33
i waiting for help but any body wanna ansewr
Originally posted by kt315 View Postpeople, C16 C18 C22 C25 must be UNCERAMIC type. you must remember it.
i have 3 kind of 1n4148
(1n4148 ST) ; (1n4148 RK ) ; (1n4148 ITT) please each one is better for delta pulse ?..........MANY THANKS
REGARDS........................................... .RAFF33
Originally posted by esus View Posthi kt 315
I've actually received an instruction uses with the sniffer very short
but I wanted to learn more about the realization of a square coil of 1mx1m
n being a connoisseur like you
I prefer not to commit any imprudence
Geo has answered my question on another post
I will advise you of the progress of the construction
especially if it works
cordially
http://www.metdet.ru/GL12x12.htm
