Bulgarian 'PULSE STAR' (... close to Legendary one)
  • mohandes
    i use two cap 10pF between them you say
    my wave of 5534 like Feng wave but the ripple more.
    i try again
  • mohandes
    Do you see how the pins on C13 are connected in the schematic and also on the PCB? Those connections do not go according to any NE5534 spec sheet that I have seen.
    Your rx signal is ringing, which (to me) indicates that the schematic connections are probably incorrect. If I were you I would try moving the C13 connection from pin-1 over to pin-8 to agree with the compensation connection in the spec sheets. The compensation capacitor should be between pin-5 and pin-1, or that's what the IC manufacturers suggest anyhow. Try it and see.
    hi i do it
    between pin 1&5 and 5&8.
    not have more change.is possible the ne5534-6 related to the flyback voltage of coil,for psg we need 500-600volts and my coil can make it at the maximum 480 volt. i am so tired.
  • porkluvr
  • mohandes
    I observe the waveform, also appears to be normal, also can detect metal, but the voice is not stable, identification of don't know how to adjust[/QUOTE]
    mr fung
    we have same problem.
    tell me you make your pcb in original or Aleximess schematic?
    mr georgi maybe problem in ne555, in original you use kt117 but i make like alex,maybe i am right?
    please come hear
  • kt315
    damping resistor value vs the waveform pin6
Name:	damping res tune.gif
  • fengzhai01
    NE5534---pin6 waveform
  • fengzhai01
ID:	337553Click image for larger version
  • georgi.g.zhelev
    PS
    Originally posted by fengzhai01 View Post
    Everybody is good, what kind of friends can also give some more carefully adjusted method? For example, 1 (...). 2 (...) 3 (...) , there is no help, maybe I can't finish the work
    Hi, fengzhai01! Please show your schemes to PULS STAR-G . (the diagram that you have done your PCB) sorry for my bad english.
  • fengzhai01
  • georgi.g.zhelev
    SEE HЕРЕ !
Name:	PS-G DIAGRAMS S SA,SB,SC  111.JPG
  • georgi.g.zhelev
    SEE !
    02-26-2010, 10:38 AM
    georgi.g.zhelev
    Senior Member Join Date: Aug 2009
    Hi! 1. DELAY > good sensitivity and stable sound .
    2. NE 5534 > pin 6 > -0,2 V
    PULS STAR-G
    HI, ALEXIMUS!Hi, tuning is done in the absence of metal in the area of the coil!
    1.RV7, RV8 obtain TP3 = 0volt. dual beam oscilloscope after the tone
    the output of U6a, b. (TP1,TP2)
    2. ZERO push and relax, RV11; indicator "discrimination." 0!
    3.RV9 ;TP5 around 0.5 .... 06v (maximum sensitivity and stability)
    RV11, replaced the potentiometer (see photo PULS STAR-G front panel) is a indikator RV11.
    SUCCESS!
    P POWER SUPPLY FROM BATERY!!!!Hi!
    "after I adjust the output is zero, then adjust the DELAY when the output is completely changed, is not zero"> This is normal !
    [ATTACH]26111[/ATTACH]Hi, everybody, I can't adjust the stability of the sound, the sound is very messy, the NE5534 (pin6) to adjust how many v?? DELAY should be in the position of maximum or minimum, and then put operation amplifier zero
  • mohandes
    thanks
    please put the pics for pin6 ne5534 and pin3 ne555.(use two channel of scope together)
    say me about the coil ,res parallel and all set you on oscillograms.
  • fengzhai01
ID:	337507Click image for larger version
ID:	337508I observe the waveform, also appears to be normal, also can detect metal, but the voice is not stable, identification of don't know how to adjust
  • mohandes
    hi fung
    first set ne555 like oscillogram(fcy 120hz and pps 150 to 400mks)
    next set all,carefull you should be have waves in a,b,c points in 4053 like oscillogram and ne5534 too.if one of them incorrect you have problem.now look at the 55534-6 wave, should be nulling and set pin 6 on 0volt then set the figure by res or delay.( georgi say on -0.2volts)
    when you adjust all parts of oscillator should adjust all tl062 like that georgi say.
    next your detector is perfect.
    your pcb is very perfessonal.
  • fengzhai01
ID:	337502Hi, everybody, I can't adjust the stability of the sound, the sound is very messy, the NE5534 (pin6) to adjust how many v?? DELAY should be in the position of maximum or minimum, and then put operation amplifier zero
