Pulse star 2 pro
  • Pulse star 2 pro
    Hello friends... I own a Pulse Star 2 Pro pulse induction device. I was not well acquainted with these devices and that they work on large targets. So I opened the device and rotated the blue resistance to pick up the gold. It worked somewhat, and it began to pick up small pieces of gold on it. High sensitivity, delay1, and it does not pick it up in other modes. Because those modes were made to have little ground effect, now I want to return it to the factory settings, i.e. the value it was at before the change. Thank you.
    Pulse Star 2 is intended to be used with coil frames for big/deep targets, not for coin-shooting.
    There are better options for coin-shooting and Pulse Star 2 Pro ain't one of them.​​​​
      My friend, it is definitely designed for big goals, but with the small file it captures small goals....
        The thing is, it can not detect small targets without changing the coil and modifying the circuit.
        So no, it is not a good option for nuggets (or at least out-of-the-box), unless you plan on spending 1.5-2k for detecting nuggets that an ACE 350 could detect.
          there are three boards. which you mean?
            Motherboard
              have just pics in low resolution... SO, may you send me pics of board in HR, 5-15 MBytes size?
                  kt315 do you have the schematic for Pulse Star 2 pro?
                    sorry not. the guys have a schematic of Pulse Star 2 (not Pro, Pro is done on two PIC chips) but do not want to share.
                      Hi , are you ok?? Send sechematic pulse starll for gmail i'm
                      [email protected]
                      thank you...
                        Hi please send me shematic pulse star 2 pro
                        Gmail: [email protected]
                        Tank you
                          Would you please send me all files for pulse star II. Thanks
                            Could you send me the files for Pulse Star II Pro?. Thanks a lot.
                            [email protected]
                              Hi Nikolaos and all others who ask for Pulse Star II Pro,
                              I also would like to see a copy of the Pulse Star II Pro schematic.... but if you would have read all posts you would know that no body has one to share or can share it. We all need to accept it.
