PI Schematic or kit with frame coil
  • PI Schematic or kit with frame coil
    Hello,
    I am looking for a schematic or kit for a PI metal detector that can work with a frame coil 1m x 1m.
    It should have the location signal with an analog display (meter) and a click rate, which when idle works with a click at some khz by a strong signal.
    I would be very happy about your suggestions.
    Best Regards
    Wolly
    Delta Pulse?
    Orbit ivconic
      Originally posted by Metallsucher View Post
      Hello,
      Best Regards
      Wolly
      Click image for larger version  Name:	dataurl785062.png Views:	27 Size:	416 Bytes ID:	419121​
      Usually, amateur pulse detectors work at a low frequency - Hz.​ In addition to delta pulse, the Polish development AVT 5196 is also suitable for amateur search.​My advice is to look for a project with a verified schematic and a verified board.​
        unpolish development. russian made. Schults show https://www.youtube.com/watch?v=j5n9-YdO4e4
