Surf pi 1.2
  • Surf pi 1.2
    Hello.
    I have a problem with my surf pi 1.2 (I have the right PCB this time). It emits a continuous sound and I can adjust the intensity with the tune potentiometer. However, when I pass a metal target there is no reaction. Do you know where this could be coming from?
    For the disc I made 26 turns of enamelled 23awg copper wire (1.7 ohm and 0.48 mh). I then surrounded it with a metal shield (like the YouTube video of the surf detector).
    I got the components from a local shop.
    Thanks for your help.​
    Do you have an oscope?
      Hello,
      yes I have an oscilloscope, where do I plug it in?​
        The closest wall outlet. Sorry, just kidding. It sounds like the TX is working (you have audio) so start with the preamp, probe the output and wave a target, see if it responds. Check to see if the demod is getting a clock signal. Keep working from the front (preamp) to the back (audio). Also check that all power supplies are proper, especially if there is a charge pump.
          long board? has mistakes. everyone doing long board begins a talk from 'HELP SOS PROBLEM' and never i see happy end.
          do you need a link at the forum thread seeking?
            That sounds you did not make a gap in the coil shield.
              I bought a fake chip last month but the coil didn't work. I tried replacing the lf357n CD4011 CD4046 board with the lf357 one and it worked fine. I also replaced the 4011 and it worked fine
                Hello. I'm new to electronics and I'm using this project to learn.
                Where should I connect (pre amp etc) and what value should I have?
                What is a charge pump?
                Do I have to make a hole in the coil shield? How do I do this?
                I will try to change the integrated circuits to see.
