As mentioned in some other posts of mine I have inherited a metal detector design and I want to make some improvements to the pulse circuitry. Currently I have a P-Channel FET configuration that works well but gets very hot. I want to change it so the main switching element is an N-Channel FET, so I can choose better avalanche and RDSon characteristics (amongst other things). The original circuit looks like this:
My new design is the following:
![2024-05-21 11_17_43-LTspice - [Draft2.asc].png Click image for larger version
Name: 2024-05-21 11_17_43-LTspice - [Draft2.asc].png
My question: Can improvements be made to the switching topology? L1 and R5 are limitations as they are intrinsic to the coil and cannot be changed. L1 (the search coil) must also have one side connected to ground as a further limitation. There is no push-pull circuit this time, would this possibly cause an issue regarding switch-off time? Would an N-channel driver improve the performance of the circuit? I also intend to use a different MOSFET, I have only chosen the IRF840 as it seems ubiquitous - what's the best option FET if budget is not a limitation?
