GoldScan-6
  • Detectorist#1
    Also using of ADA4610 as input RX stage with 30nV voltage noise at 2Hz will reduce drastically the distance of recognizing of the targets.
  • Detectorist#1
    Hi hunter63,
    My comments: With the first delay of 10-20us forget about small objects. This project is like wearing a boxing glove to swat flies - but without success! Too many expensive parts for very disappointing results.
  • hunter63
    They are not difficult, usually on two transistors, three LEDs, a zener diode and that's it
  • hunter63
    For power supply, I plan to use PowerBank 20000mA/12V
  • Altra
    Okay, no I don't have any battery test diagrams. They can be tricky and depend on the battery type being used.
  • hunter63
    Hello Altra
    Battery Health Test Regards​
  • Altra
    What is a BT.Test diagram?
  • hunter63
    Hello
    They are not very expensive, around 16E, you can easily buy them at TME.EU
    You can use a lower power one, much cheaper, but I used it with reserve. Do you have a BT.Test diagram?​
  • Altra
    Originally posted by hunter63 View Post
    Hello I am resuming the topic of GoldScan, as I promised, I am posting a freshly developed diagram.​
    You might want to consider a different power supply configuration. The AM10CW-2405D-NZ are very expensive and appear hard to find. Maybe there is an alternative brand?
    https://www.findchips.com/search/AM10CW-2405D-NZ
  • hunter63
    started a topic GoldScan-6
    GoldScan-6
