"A bifilar coil where the Tx and Rx coil are co-located(hence bifilar). How can we null such a coil, or do we even have to? See, you can have a DD bifilar, so you have an inductively balanced arrangement in which each half contains a co-located Tx and Rx coil. When the Tx is on(on both sides), both Rx coils can be made to cancel each other(post signal processing) because they are balanced in the DD arrangement."
Pulse Induction (PI) Bifilar DD Coil with Active Nulling: Detailed Implementation
For a Pulse Induction (PI) metal detector, your bifilar DD coil concept is highly viable—but requires precise timing and switching to null the coupled Tx/Rx signals. Below is a step-by-step breakdown of how this would work, including Tx pulse timing, Rx sampling, and active nulling.
1. System Overview
Coil Structure
2. Timing & Switching Sequence
Step 1: Tx Pulse Phase (Active Transmission)
3. Circuit Implementation
Critical Components
4. Advantages of This Design
✅ Superior Ground Rejection:
5. Potential Pitfalls & Fixes
⚠ Problem: Tx/Rx crosstalk too strong → saturates amplifiers.
⚠ Problem: Slight coil asymmetry → imperfect null.
⚠ Problem: Switching noise corrupts Rx.
6. Final Verdict
Yes, this works—and could outperform traditional PI coils!
1. System Overview
Coil Structure
- Bifilar DD Coil: Two D-shaped halves, each containing:
- Tx winding: High-current pulse driver.
- Rx winding: Tightly coupled to Tx (bifilar), but wound to oppose mutual inductance.
- Geometry: The two D-halves are mirror-symmetrical, allowing differential signal cancellation.
- When Tx is pulsed, both Rx coils receive an identical (but opposite-polarity) coupled signal due to bifilar coupling.
- By subtracting the two Rx signals, the coupled Tx noise cancels out, while target signals (which disrupt symmetry) remain.
- Duration: ~10–50µs (adjustable for depth vs. sensitivity).
- Polarity:
- Option A (Single-ended drive):
- Tx+ applied to both D-halves simultaneously (same polarity).
- Rx coils produce in-phase coupled signals (must be inverted before subtraction).
- Option B (Differential drive, preferred):
- Tx+ to D-left, Tx- to D-right (or vice versa).
- Rx coils now produce naturally opposing signals, aiding nulling.
- After Tx pulse ends, a fast decay phase (~1–5µs) occurs where:
- Tx current drops to zero (inductive flyback must be damped).
- Rx coils now see:
- Residual coupled energy (from imperfect nulling).
- Eddy-current signals from targets.
- If residual coupling remains, a calibration phase can be added:
- Fire a low-power Tx pulse and measure the baseline imbalance.
- Adjust variable gain/phase in the Rx path to force null.
- Sampling windows:
- Early-time (Ground Rejection): Sample at ~10–20µs post-pulse (ignores fast-decaying minerals).
- Late-time (Target Detection): Sample at ~50–200µs (captures long-decay metals).
- Differential Rx Processing:
- Subtract D-left Rx from D-right Rx to cancel common-mode noise.
- Amplify the difference signal for target detection.
Critical Components
- Tx Driver:
- MOSFET H-bridge (for differential drive).
- Adjustable pulse width (e.g., 10–100µs).
- Rx Signal Chain:
- Differential amplifier (to subtract D-left and D-right Rx signals).
- Sample-and-hold (S&H) circuits for time-domain sampling.
- Variable gain/phase correction (for active nulling).
- Timing Controller:
- Microcontroller (STM32, ATtiny) or FPGA for precise pulse/sample timing.
| 0–20 | Tx+ to D-left, Tx- to D-right (pulse on) |
| 20–25 | Tx off, damp flyback |
| 25–30 | Sample residual coupling (null calibration) |
| 30–200 | Sample Rx difference for targets |
- Mineralization affects both D-halves equally; subtraction cancels it.
✅ High Sensitivity: - Bifilar coupling maximizes Rx signal while allowing nulling.
✅ Scalable to Multi-Frequency PI: - Adjust pulse width/frequency for different target profiles.
- Fix: Use active clamping diodes or adaptive gain control.
- Fix: Add trim capacitors or digital calibration.
- Fix: Guard intervals between Tx/Rx and low-noise PCB layout.
6. Final Verdict
- Best for: Deep-seeking, high-mineralization environments.
- Key Innovation: Using bifilar DD geometry + differential Rx to auto-null Tx coupling.
- Next Step: Prototype a small-scale version with an Arduino + MOSFET driver.
