Hi DIY enthusiasts,
Now, I propose an idea for bipolar PI detector combined with magnet sensor with Super DD coil. The magnet sensor in "Fe" mode is enough sensitive to recognize bottle cap from 20-25cm as sure Fe target. 25cents USA are recognized from 25-30cm and in "ALL" mode is possible to recognize under gram targets. All this is possible ONLY on relatively flat environment with relatively homogenous soil. The benefits of this solution are:
- good EFE suppression
- automatic GB
- no need to use of input OpAmp with extremely low noise at very low frequencies
- no dangerous to activate mines with magnetic activation
- using of standard USB-C home charger
The scheme of this MD is attached.
I'm open to discussing on this solution.
- automatic GB
