Felezjoo Hex Volcano PI
  • Felezjoo Hex Volcano PI
    Has anyone seen this hex file? It's for the Felezjoo, and it's for use with a 20x4 LCD. It also uses a different program, but it has a demo counter.
    If anyone wants to test it, feel free.​
    Thanks for that.
    That looks nice and i would give it a chance, so is there a schematic or bcb changes?​
      It uses the same schematic, but its operation is different, and remember, it's a demo. You'll realize this when you test it. Finally, the designer has already abandoned it; I'm picking it up again.
      But I'm a bit short on money, so I hope to resolve this or get some funding. For now, I'm also working on Felezjoo. I've already finished it—well, it's just the prototype—but I must say it works well after many adjustments to the program.​
        I almost forgot that to use this program, a 16MHz crystal is required.
        Also, the fuse configuration is different, in case anyone wants to test it.
        LOW FUSE: FF, HIGH FUSE: DE, EXTENDED FUSE: FF
        Those are the necessary changes; everything else is the same.
        I hope to build one soon to test it and see the differences between this one and others.​​
