Help to design a PCB for my PI design!
  • Delbert grady
    How about a competition
    You post the schematic and source code here and we see who can post best PCB design.
    How does your design cope with Dickspy problem.
    Delbert
  • 1843
    Hi 1843
    Consider that when you test on the earth may be you will have more
    Falls signals . seem as your devices designed at high sensitivity and that
    Will produce instability on the ground.
    Best regards.
    First its Gain isn't more than SD2000 or Deltapulse. Second a GB solves the problems!
    Originally posted by zenit52 View Post
    Hi 1843,
    It is very interested,
    One atmega PI can be a good point to make nice and powerfull PI MD,
    Please put some photo and schematic and source code of avr that you use,
    your write this code by C or Basic ?
    we waiting for you... dear,
    have a nice day...zenit52
    Thanks for your interest!
    The schematic is not drawn yet;
    Neither, the source code is in Assembly language and I don't contribute it.
    Best regards,
    1843
  • zenit52
    Hi 1843,
  • aft_72005
    Hi 1843
    Best regards.
  • 1843
    Hi 1843
    Are your test result on workbench or on the ground?
    Best regards.
    Hi Aft,
    Workbench... there are a lot of noise here, Unfortunately I live in an apartment and can't goto an open area.
    To others:
    It may someone think I'm willing to make money by that... No! it's 100% free.
    Best regards,
    1843
  • aft_72005
    (Excellent depth...2 to 3 times more than HH).
    At a noisy invironment(also a prototype noisy PCB) it detects a gold ring(1g) at 22cm with a 3" coil!
    Hi 1843
    Best regards.
  • 1843
    I forgot to say that its easy to either design and build. The output of preamp(5534) is directly fed to the uC's ADC.
    There are no analog sampling, switch, VCO, etc.
    1843
  • 1843
    started a topic Help to design a PCB for my PI design!
    Hi friends,
    I've designed a PI with ATmega8 and a 2*20 LCD. It works very stable... (Excellent depth...2 to 3 times more than HH).
    At a noisy invironment(also a prototype noisy PCB) it detects a gold ring(1g) at 22cm with a 3" coil! (also the coil inductance is low 250uH)
    But who would like to design a PCB for it?
    I am very very busy these days...and have a lot of troubles... I can only draw a bad schematic for it...
    Best regards,
    1843
