Hi
Maybe someone knows how to synchronize these two generators?
HTML Code:
#define WAVEFORM_SAMPLES 400
HTML Code:
int f = 5000;
HTML Code:
#include "driver/i2s.h"
#include <driver/ledc.h>
#define SAMPLE_RATE 1000000
#define WAVEFORM_SAMPLES 400 // 5khz
int f = 5000;
//#define k SAMPLE_RATE /f/2
//#define WAVEFORM_SAMPLES 1000000 /2
//#define WAVEFORM_SAMPLES k
uint8_t stereo_buffer[WAVEFORM_SAMPLES * 2];
uint8_t wave_data1[WAVEFORM_SAMPLES];
uint8_t wave_data2[WAVEFORM_SAMPLES];
void generateWaveforms() {
for (int i = 0; i < WAVEFORM_SAMPLES; i++) {
wave_data1[i] = (uint8_t)((255 * i) / WAVEFORM_SAMPLES);
wave_data2[i] = (uint8_t)(127.5 * (1 + sin(2 * 3.14159 * i / WAVEFORM_SAMPLES)));
stereo_buffer[i * 2] = wave_data1[i]; // DAC1
stereo_buffer[i * 2 + 1] = wave_data2[i]; // DAC2
void setup() {
Serial.begin(115200);
generateWaveforms();
i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN),
.sample_rate = SAMPLE_RATE,
.bits_per_sample = I2S_BITS_PER_SAMPLE_8BIT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = I2S_COMM_FORMAT_I2S_MSB,
.intr_alloc_flags = 0,
.dma_buf_count = 8,
.dma_buf_len = WAVEFORM_SAMPLES * 2,
.use_apll = false,
i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
i2s_set_pin(I2S_NUM_0, NULL);
i2s_set_dac_mode(I2S_DAC_CHANNEL_BOTH_EN);
i2s_set_sample_rates(I2S_NUM_0, i2s_config.sample_rate);
ledc_timer_config_t timerConfig = {
.speed_mode = LEDC_LOW_SPEED_MODE,
.duty_resolution = LEDC_TIMER_10_BIT,
.timer_num = LEDC_TIMER_0,
//.freq_hz = 10000,
// .freq_hz = 5000,
.freq_hz = f,
.clk_cfg = LEDC_AUTO_CLK
ledc_timer_config(&timerConfig);
ledc_channel_config_t channelConfig1 = {
.gpio_num = 33, //
.channel = LEDC_CHANNEL_0, //
.timer_sel = LEDC_TIMER_0, //
.duty = 512,
.hpoint = 0
ledc_channel_config(&channelConfig1);
ledc_channel_config_t channelConfig2 = {
.gpio_num = 32, //
.channel = LEDC_CHANNEL_1,
.duty = 512,
.hpoint = 256
ledc_channel_config(&channelConfig2);
void loop() {
size_t bytes_written;
i2s_write(I2S_NUM_0, stereo_buffer, sizeof(stereo_buffer), &bytes_written, portMAX_DELAY);
Serial.print( "f = "); Serial.print( f );
// Serial.print( " W = "); Serial.print(SAMPLE_RATE /f/2 );
Serial.println();
