Rare White's Electronics Beach hunter ID Waterproof Test Bench Board - PT-1871
  • Rare White's Electronics Beach hunter ID Waterproof Test Bench Board - PT-1871
    Rare White's Electronics Beach hunter ID Waterproof Test Bench Board - PT-1871 https://ebay.io/m/xDNxbU
    HISTORICAL PROVENANCE & CONDITION STATEMENT:
    This diagnostic fixture was pulled directly from the active production line and verified in full working order upon the official factory closure in 2020.
    It went straight from live technician use into climate-controlled storage, ensuring all internal components, switches, meters, and sealing gaskets remain in pristine, unaltered condition.
    this has not been tested since I recently picked up from original storage facility.
    Guaranteed fully operational up to the day of factory closure
    ITEM OVERVIEW:
    Up for auction is a premium, highly specialized piece of marine metal detector manufacturing history: an original White's Electronics Beach hunter ID Waterproof Test Bench and Calibration Station (Internal Factory Model PT-1871).
    Sourced directly from the 2020 Sweet Home, Oregon factory liquidation, this custom setup was engineered to calibrate underwater machines.
    FEATURES & COMPONENTS INCLUDED:
    Clear Testing Control Pod: Features an authentic underwater control shell from a Beach hunter ID detector molded in clear plastic. Factory technicians utilized this clear housing specifically to monitor the internal circuit board alignments, LED targets, and compression sealing gaskets visually while running active diagnostic bench tests.​
    Yellow Marine Interface Faceplate:
    Equipped with the signature high-visibility yellow control interface featuring full dials for GROUND (salt/mineralization balance), SENSITIVITY / BATT CHK (Power toggle and threshold testing), and THRESHOLD (background audio hum adjustments), alongside the Master Mode switch (All Metal / Disc / Reset).
    Heavy-Duty Production Alignment Board:
    The control housing is mounted directly onto a large, heavy-duty black plastic backing board equipped with custom-milled thick acrylic guide blocks (retaining original aged factory tape anchors) where a detector's handle or lower shaft framework could be locked flat during calibration
    Factory Bench Notation & Harnesses:
    Retains the original internal factory wire harnesses, multi-pin connection plugs, and original handwritten masking tape on the top right reading "TDV / TDI" for multi-platform diagnostic records
