thanks
what about the cable it self? anything special about it?
Little help :D
i have a question
what type of coil connector should i use??!
tell me everything about it because i can't find it
For a good explanation of how PI detector work you can read Carl Moreland's Hammerhead article located here .Originally posted by eessoo View Posti can't afford one
but i can access one
i just don't know how to use it
and i'm in mechanical engineering so i don't really understand how this metal detector work
Instead of 74HC221, Surf PI uses CD4093 to generate sample timing. So, look at the app notes in the attached datasheet for an explanation of how the CD4093 can make a one-shot multivibrator.Attached Files
i can't afford one
Isn't it time you purchased a dual channel oscilloscope so that you can troubleshoot logically instead of guessing?
1,2,3,4,,,,,,,,
Hi eessoo
Congratulations on the third and expected fourth.
-Do you have one working and the two do not work Compare between three will reach a solution.
-Read attention in reply#59 by maiki.
best time
j.
Guys i need your help again
what is wrong with board?!! ( it doesn't make any sound )
is there a difference between PH4148 and 1n4148?
and i used 1n4007 not in4001
Thank you
guys
how long will this battery last if i connect 4 metal detectors at the same time?!
12v 4amp
http://ram-e-shop.com/oscmax/catalog...oducts_id=2064
guys please try and help me with this
http://www.geotech1.com/forums/showthread.php?t=19530
Guys it's working
it can detect coin from 20cm
it makes beeeb when the metal is near
Thanks guys
