Tesoro Cibola
  • Merc
    I fixed the oscillator supply. Changing U3 is more involved. More connections.
    MercClick image for larger version
Name:	Cibola_Original (corrected).JPG
  • Davor
    While you are at it, you could replace the U3 symbol with U12 symbol to make it consistent and easier to read.
  • Merc
    Hi, theres no supply on the oscillator.
    S
    You are correct. I did that when I was adding 5V somewhere else on the schematic. Looks like I did a cut and paste instead of copy and paste and erased it from the oscillator. I'll fix it.
  • Jabberwock
    many thanks merc,
    i have seen it now in your schematic (i need goggles)
    what substitute as a wired standard component can i use instead of this smd version
    i have ivconic´s standard pcb variant (wired components)
    i think i am finished up to 95% some little parts hard to find, like this uncommon pico farad caps
    but will post it when i get ready
    thanks again for fast answer
    Hi, I'm trying to finish the same board as you. I used 1N4148 for bas16. I got the uncommon caps from *bay and I have some spares, if you can't find them easily, one letter from France will cost almost nothing, just drop me a postal address.
    I still have to solder the external pots and test it, but I'm having some trouble understanding the voltage written on the schematics. I can see the bridge between 2 spots on Ivconic's board, but I don't understand on this board how you can get the +5V at R50 at the same time you get +9V at R21. On Ivconic's board, R16 is supposed to be bridged to R50, so it will get +9V too. where is my mistake?
  • golfnut
    S
  • Merc
    A common 1N4148 or 1N914 should work just fine. Nothing special.
    Merc
  • bernte_one
    many thanks merc,
  • Merc
    It is a standard small signal diode in a surface mount package.
  • bernte_one
    With additional infos that i got recently; i made corrections in Cibola schematic and finally made it.
    There are many differences between "original" one and the one i made.
    The one i made now is working indeed decent.
    So far i tested it ONLY in DISC mode and therefore i can't claim anything relating to All Metal mode and Nonmotion.
    I get decent air distances for various items.
    GEB is working just nice; rejects all minerals, ferrite etc...
    Disc is working excellent!
    Treshold is working, Sense is working... seems everything is on it's place.
    I couldn't obtain some of "original" ic's so i made series of checks and tests and established most proper ic's for present conditions that i have now.
    Funny thing, but TL061 is performing very well at RX front end!?
    Much better than a pile of other types that i tested!
    I intentioanlly wanted to avoid second 4053 and instead i will use ordinary mechanical switches, by now i only made wire jumpers so to settle it only in Disc mode.
    Also i intentionally wanted to avoid use of CD4024 and instead i used simple VCO taken from White's Classic schematic.
    Without additional buffering; 7660 will not synchronize directly via resistive coupling so i used most simple method: capacitive coupling!
    What to say? This thing is working and it is working indeed very decent!
    I have original Tesoro coil (for Tejon, Cibola and Vaquero) and all the checks i did with it.
    Cheers!
    hello
    still not finished by myself
    one question: there is a diode D5 (upper right corner) in the shematic named 16, is it a zner diode 16V ?
    thanks
  • Merc
    I edited the image to make corrections. Any other changes needed?
  • golfnut
    U3 has No pos supply.
    S
  • Merc
    C47 also
  • Derx
    С39 also ))))))))))
    too many errors for one sheet )))))
  • zomby
    also C38 C39 Click image for larger version
ID:	337029 inversely
  • Merc
    C51 appears to be reverse polarity.
