All Surf Pi Pro Problems
  • All Surf Pi Pro Problems
    Hello everyone
    since i entered this forum i decide to make Surf Pi Pro so i did search but for sorry i didn't made well search
    so after i made my MD i faced a lot a lot of troubles first it was dead no any signal then after a lot of working it become gives all beeeb all the time with or without coil
    and at last and finally i got it worked but with very low range so it can detect medium object at about 8 cm only !!
    i searched all over the forum and found that everyone made this MD faced this problems some of them give up and left it
    and some works for them good
    so iam posting this thread for those people who their MD worked with them correctly to help us and give us their success try
    here is the schematic i worked from and PCB
    and this is the updates i made with my MD
    to help all those who have problems with their Surf Pi MD
    my Readings in volt is
    7660
    pin 1 :1.75 v
    pin 2: 2.43
    pin 3:0
    pin 4:-2.29
    pin 5 :-4.59
    pin 6 :0.75
    pin 7:5.02
    pin8 : 4.97
    4093
    pin 11: -3.49
    pins 3,4: -4,37V
    pin 10 : -4.59
    4066 has 5V on pin 14
    4066 has -4,59V on pin 6, 8, 9 unused part
    4066 has -4,59V on pin 7 and when i measure pin 11 it gives small beeb
    358 has 4.99V on pin 8
    358 has -4.68V on pin 4
    NE5534
    pin 1 :3 v
    pin 2: 0
    pin 3:0.03
    pin 4:-4.68
    pin 5 :-0.27
    pin 6 :0 "can control by offset"
    pin 7:4.97
    pin8 : 2.91
    NE555
    pin 1 :0 v
    pin 2: 6.25
    pin 3:10.80
    pin 4:12.39
    pin 5 :8.28
    pin 6 :6.39
    pin 7:6.39
    pin8 : 12.38
    IRF9640
    G:10.81
    D:0.10
    S:12.39
    2N3906
    E: 12.29
    B: 11.71
    C: -3.50
    Notes : this values could be right or wrong until someone confirm it for us
    iam using coil with diameter 20cm ,0.4 ,22 turn
    you can also check that your 555 pulse works good by using this method from "WM6"
    " you can build your own simple audio testing utility out of an old small speaker or earpiece (nominal R from 8 to 32 Ohms) some insulated cable wire, testing clamp to connect to ground of your Surf PI, one resistor of 1kOhm and testing probe (you can made out of some hard insulate wire). Look at drawing:
    After building your audio testing utility, test your TLC555 first (test probe at pin 3 of TLC555, clamp at one of Ground points). If TLC555 works properly you need to hear loud tone from your audio utility. "
    Please guys who made this MD and worked for them please tell us everything included clear photos of your circuits
    sorry for long article
    Mohamed Ghitas
