on the draft of the gold gun shematic which transistors are suitable; BF245b or BF244b???
transistor
For your needs both transistors are OK. Critical parts is here double ferrite antenna with here proper gap. You tune RX frequency using proper C according given L value.Originally posted by taxma1981 View PostSome samples from the receiver, what show; I am a novice
Both transistors are very sensitive to static charge and can be easily destroyed, so take care how to solder it.
At the end: this is "long range locator's" theme.
