DIABLO Gold Demon
  • #31
    DIABLO I and II diagrams, and a "original" PCB
    Happy new year for all the Geotech forum members!
    I'm posting new versions of the DIABLO schematics. I've found a minor mistake around of the LM392 in the schematics that I drew before. They are now correct.
    I also drew a PCB reversing the original Tesoro's design. I'm working in a new one smaller than this, but still needs some adjustments. In a few days, I hope I can post it.
    Fabián
    DIABLOII.rar
    Tesoro DIABLO.pdf
    Tesoro DIABLOII.pdf
    • #32
      Excellent work Fabian.
      If you are interested in factual Tesoro Diablo II board dimensions, here (bottom view) drawing for help:
      • #33
        Thank you WM6. It's good to know it, but the original Tesoro box it's impossible to find (I think so) and is for that, that I made a squared board. I think it is simpler to fit into any box.
        I'm watching that my drawing is little bigger than the original and surely is caused by photo's deformation. I think that it could be reduced with little effort. As I say in my previous post, I´m working in a new board, based in the schematics and the LOBO's board, that I started to draw before to know your photos and this is smaller, closer to the original. I will publish soon.
        Fabián
        • #34
          hello Fabián,
          did you finish the ne pcb layout? Would you post it here?
          • #35
            DIABLO I & II PCB's
            Hi Bernard. Here it is. The PCB is working, but my "nightmares" (homemade coils) still doesn't like me totally. A friend of mine bought a original coil in eBay for me in the USA, and I'm still waiting for it arrives.
            I'm planning to buy a ten turn potentiometer in eBay too, cause I only have a 30 turns pot from an old VCR or a TV. (Maybe it could be better, I still don't know)
            Anyway, the PCB of the DIABLO I, for me, works well and it could be a good notice that somebody start to build another one to compare it.
            Hope that you can do it.
            Fabián
            DIABLO I & II PCB's.rar
            • #36
              Hello Fabian,
              good format of both pcb, many thanks
              best regards Bernd
              • #37
                Thank you Bernard. It took me a lot of work and time, but I'm happy about the result.
                In a few days, when the coil finally comes, I will work again with this project.
                Regards.
                Fabián
                • #38
                  nice work,data for coil?
                  and different between two version?
                  • #39
                    Thank you Mohandes.
                    The specs of the coils are the same of the old LOBO published here in the forum, as I wrote in the schematics. I used 0,25mm wire for the TX and 0,20mm for the RX, and the necessary turns to achieve the inductance and resistance.
                    About the differences, DIABLO II have a "Mineralization Switch", that does not exist in DIABLO I, and the Threshold control pot is not in the rear panel but in front panel.
                    Fabián
                    • #40
                      For those interested, here our friend "ivconic" version of (Sprint Layout) board:
                      • #41
                        As master Ivconic always does, a very good work...
                        Fabián
                        • #42
                          Niemand is perfect, controleren voordat u het te maken en laat het gebruik weten if it werk. Grt Nakky [attach] 32311 [/ attach] [attach] 32312 [/ attach]
                          • #43
                            Nice work nakky.
                            You didn't "controleren" it?
                            • #44
                              Dankzij WM6,
                              Ja ik heb het controleren met schematische Tesoro Diablo goud demon-by Fabian en WM6 (2014).
                              Grt Nakky
                              • #45
                                Dankzij WM6,
                                Grt Nakky
