i can show that with magnet on any sand - thats normal. you do something wrong. shield
a space inside box, around the pcb. connect the shield to the ground. both points of shileding must be in one point -
from coil and from housing to the batts clemma.
Malysh FM
You must comply that the author has two projects Malish FM and Malish FM 2. For each of the two projects is over, as the schemes and programs for the CPU changes were made.
Here are the latest two versions. Note that under Malish FM-ver2 coil is 1.5 mH, while the second version Malish FM2-ver2 coil is 2 mH.
In second new version (Malish FM2-ver2) the author has waived coil wound on the ferrite rod.
In the first two versions the inductance of the coils is as follows: Malish FM - 1.25 mH and Malish FM2 - 2,290 mH.
I hope that now becomes clear where it comes from frustration with inductance coils.
ask http://www.geotech1.com/forums/member.php?5584-Eddy71Originally posted by ripsdevala View PostWhat is the right coil spec 2mh, 1.5mh or 2.290mh?
I use 2mh for now
I use 2mh for now
Is malysh fm2 always give signal when close to soil/ground? Already wrap it with foil nothing change
thanks again kt315
i have pointed some mistakes on my pcb and overall it don t works so i m going to do another pcb with my modification just to see
thanks for the usefull link
