2 Coils and 6 Transistors Metal Detector
You are the profi, thanks for the link!Originally posted by 6666 View Post
OK, there is written on the page:
> The 16 cm coil is just about perfect for coins and rings.
Very good, if Hammerhead builts it to search for rings on the beach of Alexandria he
has now the correct advise but for luck with our modern detectors coils from 25-35cm
are still perfect for coins and rings and they are much faster for larger areas.
Anyway - the good thing is that now we have with the:
an useful schematic because on that "drawing"
at the website not even the transistors are typified.
The transistors can be just about any small signal transistors actually, 2n3904, 2n2222, bc107-9, bc547-9. If what you happen to have are PNP transistors, you can flip the schematic and have a working detector.
But without a shielded coil, a BFO will be pretty lousy to use, particularly in wet grass.
