TM808 FREQUENCY CHANGE
The 16 Volt power rail is something that you have to consider. 15 Volts is a common max quoted in datasheets for some 555 variants.
If you want alternative crystal / divider replacements, here's a couple:
4.194304 MHz divide by 32, divide by 5 = 26212 Hz ( 0.6% error)
4.433619 MHz divide by 8, divide by 7, divide by 3 = 26390 Hz (0.07% error)
Both these crystals are common and dirt cheap: (binary divider, & colour TV sub-carrier)
ask Eddy and he ll change a code for PIC on freq you need. http://smartelectronix.biz/publ/mini...telja/1-1-0-43
Resonant Frequency Calculator :
http://www.1728.org/resfreq.htm
F: 6000Hz
L1: 570uH
L2: 17.9mH
correct?
