I consider the Garrett BFOs collectively to be a "classic" in metal detector history. Garrett was a leader during the brief reign of BFO and the pinnacle of their efforts was the Master Hunter BFO discriminator, the last model sold in 1981 as BFO was gasping its last dying breath. I own a couple of these units, along with the vast array of coils that were available, from a 3" puck to a 24" square, and a weighted coil with a 50-foot cable. The coil selection was one reason people liked those old BFOs so much. Otherwise, they weren't much to talk about.
I've long thought the Master Hunter BFO wasn't really a BFO, but more likely an off-resonance design that gave it the ability to discriminate. I was recently moved by the curiosity spirits to pull open one of my units and trace out the circuit. Of all the schematics floating around the Internet, I've never seen this one, so here it is.
As it turns out, it really is a BFO with a crystal used in the reference oscillator. I suspect the White's "zero-drift" BFOs did the same. But Garrett also takes the amplitude modulation off the search oscillator and combines it with the mixer output to drive the meter. I suppose that in a way similar to off-resonance there is enough variation between the two to get some crude discrimination.
GarrettBFO.pdf
GarrettBFO.pdf
