Tilikum.Ru Skif PI Auto Tune V3.2
  • Tilikum.Ru Skif PI Auto Tune V3.2
    SKIF_PI-AUTOtune on ATiny2313-10 microcontroller
    By sevzirfo
    My version of the universal pulse metal detector for the most severe operating conditions. A feature of the scheme is the presence of an asymmetrical slow auto-tuning zero offset, the use which allowed to get rid of the slow drift of the sound threshold and always search for the highest possible sensitivity
    When operating in the absence of a target, the detector emits a slow crackle, like a geiger counter, and when a target is detected, it sharply increases the frequency of the sound. With a long hovering over the target, the auto-tuning SLOWLY compensates imbalance and the frequency of the sound decreases to rare crackles, but if the coil is removed from the target, FAST reverse compensation occurs (the recovery rate is 5 times higher) and the detector will be ready for further searching. When changing coils of different sizes, the detector adjusts itself for them - auto balance coil feature, to speed up this process, the "FAST TUNE ZERO" button is provided. For a visual indication of the auto-tuning operation, a VD4 LED is displayed, which blinks periodically when the auto-tuning feature is working and the detector was set for maximum sensitivity.
    Search coils from 18cm to 3x3m were tested, with a square frame of 1x1 meters confident detection depth was 3.5 meters (target was automobile).
    Version 3.2 of the program for the ATiny2313-10 microcontroller (work at 10 MHz). Added steps (7 steps) adjustment of the pause duration before the sampling pulse (guard interval) for cutting off small objects without loss of sensitivity for large targets. Applicable to search coils of any sizes. If you search small golden targets you should make fast, low-capacitance coil. For steps switching, the controller free terminals are involved. To tune guard interval switch any of these pins of the controller must be closed to minus constantly, output polling occurs when you press the reset button.
    Skif PI Auto Tune V3.2 sch mod by Tilikum.RU
    good pustareka. this is my post done in 2008 year http://www.geotech1.com/forums/showt...IF-PI-AUTOtune
        Good KT315. this is Tilikum SKIF PI Auto tune mod. Модернизация Skif-Auto v3.2
          The Sevzirfo original is here
          This description is for those who are going to do "from scratch". Here were implemented all previous upgrades:
          adding and deleting old elements, changing the values, adjusting the pause with the buttons (with svetodiode indication).
          Here are two new "chips":
          1) The range of voltages generated by Atiny PWM is expanded from 0...5v to 0...12v by introducing a Q3 BC 847 transistor.
          As a result, removed the auto-tuning range linear regulator (in the original R16) and his associated items.
          2) The On / off button is entered (switch to standby mode and back).
          Thus, there are no variable resistors anymore, the front panel is now has 5 buttons and 4 LEDs.
          PCB designed for some Chinese housing from SANHE company. LEDs are on a separate pcb, which also serves as a mount (clamp) for the speaker.
          Power supply - from a battery with a nominal capacity of 1.2A*h, placed in the housing SANHE Z5a, the halves of which are fastened
          using fiberglass strips with soldered M3 nuts.
          This DEEP SEARCH METALLODETECTOR is for strong digger boys , not for small items and weak p...y boys. Search loop up to 3m x 3m is possible for very deep prospecting.
          Happy T.Hunting.
            Tilikum.RU Skif PI Auto Tune (offset) Mod 3.2
            Tilikum.RU Skif PI Auto Tune Mod 3.2.rar
              Katuska Coil Lup Fame 1m x 1m, 2m x 1m, 2m x 2m, 3m x 3m. Min katuska forma 60cm x 60 cm.
              1m x 1m = limuzine 3.5 m (air).
                Atiny2313
                Clock Frequency=10000000
                Без битовой инверсией (no inversive bits). Pony prog inversive bits.
                [Fuse bits]
                CKSEL0=1
                CKSEL1=0
                CKSEL2=0
                CKSEL3=0
                SUT0=0
                SUT1=1
                CKOUT=1
                CKDIV8=1
                RSTDISBL=1
                BODLEVEL0=1
                BODLEVEL1=1
                BODLEVEL2=1
                WDTON=1
                SPIEN=0
                EESAVE=1
                DWEN=1
                SELFPRGEN=1
                [Lock bits]
                LockBit1=1
                LockBit2=1
                BootLockBit01=1
                BootLockBit02=1
                BootLockBit11=1
                BootLockBit12=1
                hex.rar
                  3.2 Working device can I have a list of details ?
                    .5 volts won't work.
                      Is this schematic working ?
                        Hello, dear friends, what software do you use to program the hex file and also the eeprom of this design? I need a healthy file and how to program them, please help me.
                          The hex and eeprom files are both corrupted. Please put the healthy files here. I have completed the circuit and they are waiting for the healthy files. Unfortunately, the files in the forum are damaged. Please help.
                            you can ask our best russian friends via this direct link Просмотр форума - SKIFF-PI • Схемы металлоискателей MD4U •​
                            i hope they will be not angry birds to your request....
                              Hello, my friend, thank you, but if you can, please put the hex file and the settings of the fuses here for me, because the Russian language is difficult for me and I did not understand, if you can, please help.
