Hi
  • Hach
    I do trust my own archive from hard disk.
    I do make SMW every once in a while, respecting the schematic and pcb that i have.
    What to answer?
    I don't think too much on SMW concept any more.
    I just repeat the diy without much of a thinking. Since it is proven and works alright.
    But nobody stops you to experiment and try any other solution.
    That is very good way to learn and progress.
    It doesn't really counts what i say here, it counts only what you find that works for you.
    Go ahead and do it your way. I can only salute that.
    Regardless if I made the smw in proper way or not at least I get 20cm for coin in the ground. And I learned alot
    I used both 2.7k and now I am using now 27k both are working I asked only to be sure don't worry about it.
    Really I don't know how to thank you it's the best diy project I had ever try
    You are honest man.
    Regards.
  • ivconic
    What to answer?
  • Hach
    It is 27k as noted.
    Quote Originally Posted by smity View Post
    Ivconic, you have the last circuit (post number 520) r2 - 2k7, 27k on the circuit board. Which is correct? And tell me. Possible to set the adjustment "thresh" on the LM358, and the "sense" to remove? I think it will be continuously adjustable sensitivity. Sincerely.
    It is 2K7, sorry for the mistake!
    Possibly yes. It is also good solution.
    You can change R37 value or put trimmer instead to see the difference.
    Also i think that 555 stage can be improved further
    Are you sure is it 27k!!!
  • Vadim18
    Originally posted by hooby life View Post
    can use lm7812 regulator instead of 7809
    regard..
    You can try to use, but, you need at least 2 things - battery with 14 volts minimum voltage (idealy 4x li-ion cells) and CD4053 only, not 74HC4053 or it will overheat. But I think 74HC4053 will work better than CD version, but offcourse will work only with lm7809 regulator.
  • hooby life
    regard..
  • Hach
    Originally posted by Nandor View Post
    Geb has to much phase shift, it's too strong!
    Phase Resistor 1.8k. Should I change it?
  • Nandor
  • Hach
    Geo can anyone tell me why Smw when I reject ferrite rode its also rejected silver rings?!!
  • Hach
    Hello ivconic
    Its really work perfect in air test I get 50cm cola can
    Big iron like tea pot more than 50cm
    Wedding silver ring 20cm
    Coin 10mm 20cm
    Gib discriminate only iron coin not all iron
    TV ferrite can't be discriminate
    I test it inside room where electronics and wireless also the ground have iron in it but it's not quite at all when I face it on the ground so noise, dos this noise vanish outside?
    Also I afraid I don't connect coaxial TX and Rx in it's terminal plase look at attached image and tell me where should I connect to.
  • gurdal
    hello ivconic,
    Are there 2 tones and pinpointer in the circuit?
    If you have, can you send a video link to private?
    Yours truly
  • Hach
    thank you. i see 9.7 mln inhabitans and good growth of your people.
    Third world countries like you see same as lietuva
  • Hach
    No such thing.
    Especially not for 6v power supply and perfboard mess.
    Isn't thes enough to say that board is working and give me support!!?
    shared a video with you from the Flickr app! Check it out:
  • kt315
  • Hach
    Hach write pls your country in profile. let to see your native. i see you want to be poorer by poorest.
    my county is Lietuva with 3 mln inhabitans, but really here is 2, not more. Lietuva is fascist state because they prohibit to use
    different languages - polish, russian, belarusian.
    I live in Jordan
    Native language is Arabic
  • kt315
