hi everybody from greece thats my first post here great job everyone!!! as i said in the title im looking for scematics to build. my interest is gold coins from 2nd world war the max depth i need is 1 meter any suggestions??? thanks in advance
LOOKING FOR DETECTOR TO BUILD
How many turns has the coil of 1x1 m and how many turns has the 45 cm coil?Originally posted by GuardHi from George Thessaloniki.
A very nice pulse detector is "delta pulse"
with 45cm coil detect a gold coin to 50-60cm
with 1x1m coil detect an iron plate 20x20cm to 170-210cm
In the ground a metal boiler 50x100cm i detect it in 270cm !!!
Regards from Karditsa
Hi. What are you mean R=660OHM or 1.5K. With 1.5mm or 2.5 mm wire the resistance must be 0.3 Ohm max. Who current is 1.2 A? The averange is 75-100 ma at my delta pulse.Originally posted by Guardhi GEO.
THE 45CM COIL HAS 16 TURNS WITH 1.5MM POLIKLONO R=660 OM
THE 1X1 COIL HAS 13 TURNS WITH 2.5MM POLIKLONO R=1.5 KOM
FREQUENCY 150-250HZ
I=1.2AMP
I tried a coil with R=0.3 Ohm and the detector was unstable so i connected a resistor 2 Ohm in series with coil.
F=100 Hz
